Possible Faulty Brake Switch
Old Feb 9, 2023 | 05:49 PM
asdf's Avatar
Default Possible Faulty Brake Switch
2003 Jaguar Xj8; 120,000 miles
Intermittent lack of cruise control, failsafe engine mode message not on.
After trying for cruise control enough, the failsafe engine mode message will appear and cruise control will be completely gone.
No DTCs and the message disappears when the car is restarted.
Brake lights turn on and off as expected.
I believe this is a faulty brake switch, but someone please confirm my diagnosis.
Also, is there a way to test the brake switch with a multimeter before I aim the parts cannon at a potentially innocent component.
Old Feb 9, 2023 | 07:31 PM
RJ237's Avatar
The two circuits in the brake switch are the outer pins for one circuit and the inner pins for the other. Check the continuity with the pedal relaxed and then depressd.
Old Feb 9, 2023 | 08:36 PM
asdf's Avatar
Thank you.
Old Feb 10, 2023 | 02:16 PM
Jeroen's Avatar
Hook up an OBD analyser/scanner. There is a specific code for this problem.
Jeroen
Old Feb 10, 2023 | 03:17 PM
asdf's Avatar
There were no codes. . .
Do you need a special kind of scanner to read chassis codes as opposed to just engine codes?
Old Feb 13, 2023 | 04:50 AM
Hooli's Avatar
Don't trust just using a multimeter on the brake light switch. Mine tested fine, but replacement cured the car dropping into failsafe mode & disabling the throttle when the cruise control was 'armed'.
I saw a thread on here recently that said resoldering the microswitches to the board in the switch normally fixes the issue. I've not tried it on mine, but will as I kept the old switch because I couldn't prove a fault on it with my meter.
Old Feb 13, 2023 | 06:18 AM
RJ237's Avatar
If you do a search you will find the part# for the microswitches.
Old Feb 13, 2023 | 08:43 AM
asdf's Avatar
I have found that thread (thank you) and ordered the micro-switches. I will do a write-up once they arrive.
Armand
Feb 21, 2022 10:39 PM
Alfred Firmani
Feb 20, 2022 06:41 PM
gelair
Feb 6, 2021 10:08 AM
smith356
Feb 27, 2015 10:49 PM
Dlee
Jul 20, 2012 09:30 AM
