Is it Possible to Make one of the Cigarette Lighters 'hot?'
Old Apr 29, 2024 | 02:49 AM
Johnny_B's Avatar
Default Is it Possible to Make one of the Cigarette Lighters 'hot?'
Is it possible to (easily) make one or both of the cigarette lighters operational at all times, instead of just when the ignition is on? It would be very nice to have power at all times when I need it. I saw a video of an SUV that just needed to have the fuse put one spot over to make the lighter socket hot, but I am guessing that is not a very common design. Any help is appreciated.
Old Apr 30, 2024 | 02:46 PM
944play's Avatar
The X300 has the cigar lighters on their own relay in the #2 (counting as if they were aircraft engines) RH heelboard location. Assuming the X308 is the same, all you would need to do is replace the relay with a jumper over the high-current pins.
Old May 1, 2024 | 06:12 AM
Sean B's Avatar
As they like a good battery voltage of 12.5 and over, there's probably a reason it's ignition live. It might get you stranded.
Old May 1, 2024 | 11:42 AM
944play's Avatar
Maybe he's adding a solar battery maintainer.
Old May 2, 2024 | 06:34 PM
RandyS's Avatar
I would be carrying a NOCOboost with me because you never know
what you end up with.
Anxious Jim
Apr 3, 2025 04:20 PM
prestone08
May 13, 2018 11:43 AM
creativebush
Jan 24, 2018 10:53 AM
Fstbmw1
Apr 9, 2016 08:42 AM
Jul 1, 2012 09:25 PM
