power steering leak. 2001XJ8
Old Feb 10, 2020 | 10:22 AM
Gasworksgarage's Avatar
Default power steering leak. 2001XJ8
so what is the usual culprit? The hose or the reservoir?
Old Feb 10, 2020 | 06:58 PM
2001 White XJ8's Avatar
It was the hose on my 2001.
Old Feb 10, 2020 | 07:00 PM
RJ237's Avatar
On the XK8 it's usually the low pressure hose connection to the reservoir, and I expect the XJ8 is the same.
Old Feb 10, 2020 | 07:16 PM
Well it does look like the hose. It appears to be a formed hose. Is this available after market?
Old Feb 11, 2020 | 12:07 AM
Yes, pretty sure it is. I will look in my records and see where I got mine.
Old Feb 12, 2020 | 11:42 AM
I bought mine from Terry's and it was the High Pressure hose part number MNC3985AH. Mine failed 1.5 years ago with 145K miles on her. I had no problems with installation.
Old Feb 12, 2020 | 04:44 PM
Do you have a web address or phone number for Terrys? I am like getting hundreds from your a Google search. Thanks for the help
Think I found it. Is it in Kalamazoo?
Old Feb 12, 2020 | 05:01 PM
Is this the hose?
Old Feb 12, 2020 | 06:38 PM
No, is that what comes up under that part number. From my memory it was a combination of rubber and hard line.
Old Feb 12, 2020 | 06:40 PM
Old Feb 12, 2020 | 07:11 PM
I need the low pressure hose from the reservoir to the pump
Old Feb 12, 2020 | 07:48 PM
Wow, that one failed before the HP one. That's good, probably easier to replace.
JagYi
May 19, 2023 02:20 PM
justdANDY
Aug 21, 2018 07:49 AM
etaent
24
Oct 1, 2015 04:32 PM
YycXJS
Mar 12, 2015 10:16 PM
