Prgramming fob!
Old Jan 11, 2020 | 07:22 PM
mat32essex's Avatar
Default Prgramming fob!
I have a 1999 Jaguar XJ8 since I have had my car the key fobs do not work. The only button that works is the headlight button. I wondered if anyone had any idea how you program these fobs so they will work with my car ?.
Old Jan 11, 2020 | 07:36 PM
King Charles's Avatar
Old Jan 11, 2020 | 07:45 PM
motorcarman's Avatar
If any one button works on the keyfob transmitter, then it IS configured to the car.
The transmitter is likely faulty and needs to have the buttons 'cleaned' or the fob REPLACED!!
bob
Old Jan 12, 2020 | 11:04 PM
mat32essex's Avatar
Default Update!
Is there any problems with a car that could stop this working ?. I followed the instructions carefully a few times and it did not work. I even followed other guides I found on youtube and still did not work. I pulled the headlight stalk towards the steering wheel. I inserted the key to the first position while still holding headlight stalk towards the steering wheel. I then flashed the full beams 5 times as said. Other guides said 4 times so I tried this as well. There was no beep or anything. I even pressed the buttons and still nothing.
Many Thanks
Mat
Old Jan 13, 2020 | 08:12 PM
M. Stojanovic's Avatar
As suggested by Bob, the problem is in the fob itself. Over time, gunk will accumulate on the fob's PC board at the sensing points (where the buttons touch the board) and needs to be cleaned. Open the fob up and inspect/clean.
Old Jan 15, 2020 | 07:58 PM
mat32essex's Avatar
Default Fob!.
If the fobs are not working would this stop the car from beeping when trying to program the fobs ?.
Old Jan 15, 2020 | 11:43 PM
user 652867429824's Avatar
Originally Posted by King Charles
I think also you have to program 5 fob, so if you have 2, program 1 3 times, and the other 2 times This You Tube video will help
Nicholas Antony
Feb 27, 2026 04:45 AM
ludwig drummer
Apr 20, 2020 10:56 AM
Probesport
Mar 25, 2014 12:04 PM
YoungRobertL
Feb 20, 2012 03:54 PM
blkjag
Sep 14, 2008 11:09 AM
