Problem with Camshaft VVT?
Old Aug 5, 2014 | 08:57 AM
ericjansen's Avatar
Originally Posted by xjay8
Hey sam....I really can't see why this would be the problem....I think you're starting to clutch at straws ;o]
Yeah, I do agree, as I thought about it as well.
There should be a relation between the VVT operation (connected and operating / disconnected and not working) and the noise.
I also do not see how the chain tension should differ from those 2 situations.
Can the noise be traced back to any part of the VVT operation? Anyone with more knowledge about that?
Old Aug 6, 2014 | 05:48 AM
blackhonor9's Avatar
I changed everything else except for timing chain and cam adjuster bracket. Receiving code P1384 which jaguar mechanic stated it could be the oil flow to the vet actuator or the actuator itself. Since I changed the vet actuator I thought just change the cam adjuster bracket also.
Old Nov 1, 2014 | 05:44 PM
ericjansen's Avatar
Any more update on this one?
Eric
Old Nov 2, 2014 | 11:33 AM
I removed the oil pan oil sump to clean them and also, I changed the VVT unit. It fixed the tapping issue now the motor jumps. I think I didn't set the timing correctly and the secondary timing chain tensioner is compromised so that needs changing as well.
Old Nov 6, 2014 | 05:40 AM
ericjansen's Avatar
Take it easy, don't break her ...
Is it a hard job to change the VVT?
Any thought on WHY the VVT made this noise?
Eric
Old Nov 7, 2014 | 09:10 AM
I'm not sure. I Changed it because it was the only other part that had not been changed.
Clamdigger
Sep 12, 2015 03:43 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
