Problems from only having valet key?
Old Nov 15, 2014 | 09:15 PM
Earl S.'s Avatar
Default Problems from only having valet key?
I bought a 2000 XJ8 several months ago with only one key. I did not realize this green key is a valet key, but it is. I found out about one problem today - my battery was dead and I could not use the valet key to access the battery in the trunk - I needed to hot shot to the engine.
Are there any other downsides to using a valet key as the everyday key?
Old Nov 16, 2014 | 12:12 AM
jimlombardi's Avatar
I copied these 3 pages about the black and green keys use from the 2000 jaguar driver handbook:
If you do not have the Jaguar Handbooks, you can download the Driver Handbook & Vehicle Care Handbook:
Drivers Handbook
https://www.dropbox.com/s/4gmfd5or96...dbook.pdf?dl=0
https://www.dropbox.com/s/c6y3yn81af...dbook.pdf?dl=0
You could have opened the trunk by opening the hood and used the false bulkhead connection:
In the engine compartment on the passenger side there is a rubber cap on the false bulkhead, pull the rubber cap off the stud then put a positive jump lead on it and the negative jump lead to the chassis as a ground.
Now you will be able to open the trunk. DO NOT try to jump start the car this way.
Here are 2 photos of false bulkhead location:
Photo of the engine compartment - shows the bulkhead covers and the false bulkhead next to the passenger bulkhead cover:
Attached Thumbnails Problems from only having valet key?-false-bulkhead-connector1.jpg   Problems from only having valet key?-false-bulkhead-connector2.jpg   Problems from only having valet key?-xj-x308-front-bulkhead-covers-photo.jpg   Problems from only having valet key?-jaguar-xj-x308-keys-use-driver-handbook-1.jpg   Problems from only having valet key?-jaguar-xj-x308-keys-use-driver-handbook-2.jpg
Problems from only having valet key?-jaguar-xj-x308-keys-use-driver-handbook-3.jpg
Old Nov 16, 2014 | 07:20 PM
Reggie's Dad's Avatar
Earl, it is quite easy to modify your green valet key to be a master key if you want to use it as a daily driver key. The only difference is the width of the very tip of the key. I small file and a bit of talent will reward you for free. Ask if more info is desired. Brandon
philwarner
Oct 4, 2024 01:37 PM
Wolfy
May 28, 2024 08:06 AM
XJsc-guy
Nov 23, 2015 01:56 PM
tberg
Sep 7, 2015 07:32 AM
My Pham
Sep 4, 2015 03:37 PM
