radiator cooling fans
Old Aug 3, 2015 | 04:25 PM
Doug Dooren's Avatar
Default radiator cooling fans
My wife drives a '99 XJR and I recently noticed the electric fans continue running for a minute or two after the car is shut off. Can someone tell me if this is normal - I don't remember this occurring in the past? Thanks.
Old Aug 3, 2015 | 06:53 PM
test point's Avatar
That is not unique nor abnormal as long as they run for only a minute or less. Heat soak of the heads/coolant/temp sensor.
Old Aug 3, 2015 | 07:09 PM
rocklandjag's Avatar
Mine never ran after shut down until 2 weeks ago. I ended up needing a T-stat. Now they never run after shut off as before. If the run time keeps increasing then check the cooling system.
Old Aug 5, 2015 | 03:53 PM
Jhartz's Avatar
Mine has never run on after shutting down; but many others have. If you have a good OBDII reader, plug it in while it is running and observe the engine temp. If more than 205* or so with the fans running (and AC on) you may need to renew the TST, the coolant, and check the drive belt. Both fans should be running if it is still that hot.
Is it the original water pump?
I have had BMWs and Hondas that would run on for a minute -- it was considered normal: don't think so for these cars. Note well: (nb if you are into Latin) With 3 Land rovers and 3 Jags, I have never had an AJ 8 cylinder engine run on.
Old Aug 6, 2015 | 06:39 AM
RJ237's Avatar
My car runs at 195 F and the fans come on for about 10-15 sec. after shutdown.
Old Aug 6, 2015 | 02:08 PM
plums's Avatar
a vote for not normal here.
try a top up and bleed ... several times.
Old Aug 6, 2015 | 07:18 PM
I guess Bob breaks the tie and it's not normal. Since first posting, the fans kept running on longer - got to the point I had to disconnect the battery after 5 minutes or so. Temp gauge always read normal until today when it spiked and the indicator light came on for about 20 seconds. Just as I was pulling over the light went out and the gauge dropped to normal. Checked the coolant level after the engine cooled and it was normal. Will replace the thermostat this weekend and refill and bleed. I'm assuming this simply involves bringing the engine up to operating temp and running with the pressure cap off? Thanks everyone for your feedback - it's appreciated.
Old Aug 6, 2015 | 09:24 PM
plums's Avatar
For an effective one shot bleeding method on a XJR see the following post:
https://www.jaguarforums.com/forum/g...6/#post1281761
Old Aug 7, 2015 | 06:00 AM
RJ237's Avatar
You might want to replace the water pump, or at least remove it for inspection.
Old Aug 9, 2015 | 01:30 PM
Replaced the thermostat ($20 from NAPA here in the U.S. is the OEM part) and used the bleed procedure posted by plums. No more temp issues and no more fans running with the ignition off. Thanks again everyone.
Mac Allan
Jul 20, 2020 05:46 PM
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
vwbusbits
Oct 13, 2015 03:43 AM
bydand
Sep 27, 2015 12:00 PM
