Radio enter code ?
Old 02-21-2013, 06:54 PM
Dpk2313's Avatar
Default Radio enter code ?
I just had my fule pumps replaced and now my raido reads enter code and semes to be locked, how do I remedy this? Also my checkengine light is still on will it shut off once I " ENTER CODE" ?
Last edited by GGG; 02-22-2013 at 01:59 AM. Reason: edit typo in thread title so it appears in searches
Old 02-21-2013, 07:05 PM
GGG is offline
Received 16,825 Likes on 12,179 Posts
Not too many Jaguars in the US with coded radios so you are really unlucky.
You need to enter the 4 digit Security Code using the number buttons on the radio to unlock it. Enter the wrong code three times and the radio will lock until it's been powered ON for one hour before you get three more tries. As there's 9999 possible code combinations, guessing isn't really an option.
The Security Code will have been on a card like this when the vehicle was new:
If you have the card, punch in the code and you're done.
A missing code card is a regular issue here in the UK where all our radios are security coded. A call to the dealer with proof of ownership and quoting the VIN usually gets the code from them.
The CEL is not linked to the radio code in any way. This is a separate issue.
Dpk2313 (02-21-2013)
Old 02-21-2013, 07:27 PM
Dpk2313's Avatar
Lickily thats the only origional paper work that came with the car, thank you.
Old 02-22-2013, 02:18 AM
GGG is offline
Result.
You'll still have the CEL (Check Engine Light) on? If you haven't got access to a scantool, somewhere like Autozone will be able to read the DTC error codes and clear the light for you.
Get the actual codes and post them on the forum for an explanation of what they mean. If the fault that's causing the CEL to illuminate isn't fixed, the light will come back on.
Old 02-22-2013, 02:42 AM
steveinfrance's Avatar
Originally Posted by GGG
FOR SALE DURHAM AREA
One Jaguar radio (with security code) from damaged XK8
Seriously though, you need an OBD reader - there's a huge thread on them but I'm very happy with a cheap EBay bluetooth adapter and an Android app called 'Torque'
Old 02-22-2013, 03:11 AM
colc's Avatar
Default radio code
Further to this, I recently needed to enter my radio code, which I did, now all I'm getting is a "wait" sign....do I have to press anything else after the four digit code?
Old 02-22-2013, 03:26 AM
GGG is offline
The WAIT message appears if you enter the wrong code three times.
The radio has to be powered ON for one hour before you can try to enter the code again.
By powered ON, that means ignition ON or engine running for one hour and not just leaving the radio in the switched ON position.
Old 02-22-2013, 12:48 PM
blackwolf560's Avatar
I just call any Jaguar dealership (besides this local one who dont seem to have any anyformation about Jaguars besides selling news ones). I usually use one in Atlanta. They just ask for VIN number and they supply correct 4 digit pin for that car. This is assuming thta is the original radio that came with the car when new or else you'll have to pull the radio out and give them the numbers from the radio tag that is on the back. Takes about two minutes to retrieve info and 30 seconds to put in. Once the digits are entered correctly, the radio should just come on. Mess aroudn and get it wrong three times, it will say "wait" for very long time (about 10-15 mins) or until battery is disconnected again within that time frame.
Old 02-22-2013, 02:01 PM
Probesport's Avatar
The WAIT message appears if you enter the wrong code three times. The radio has to be powered ON for one hour before you can try to enter the code again.
I have also found that if you disconnect the battery (negative lead) for a few minutes you can try over again straight away.
Old 10-20-2014, 04:42 PM
shehryarkakar's Avatar
Default stereo locked
I changed battrey then i got this problem in stereo,then I have tried 10 tyms now its locked wat should do?
St.Regis
04-06-2021 12:34 AM
cissdm
05-03-2016 06:02 AM
Burdedw
09-12-2015 10:39 AM
TexasCat
09-08-2015 04:36 AM
philwarner
09-02-2015 11:45 AM
Quick Reply: Radio enter code ?
