Rear door window replacing
Old Jun 18, 2015 | 05:14 AM
Thomas Ahlin's Avatar
Default Rear door window replacing
Hi, new member but have been watching this great site for a while.
A villain made my day by smashing the rear door window on my 98' XJR. Got a used one but how to fit it? Can anyone please tell if the JTIS cover this? Thanks!
Thomas
Old Jun 18, 2015 | 07:11 AM
SteveSheldon's Avatar
If you PM me your email address, I have a Jaguar workshop manual I can email across to you which lists wiondow glass replacement etc if that is of help
Old Jun 18, 2015 | 09:59 AM
Thanks Steve, that would be a great help. Seems as if I can't enable PM in the CP, perhaps because as a new member I need to qualify a few days? Anyway, I enabled the vCard option, seems to work fine.
Regards,
Thomas
Old Jun 18, 2015 | 11:03 AM
No problem - I have sent you my email address by p.m. - drop me a line and I'll email it back to you :-)
Old Jun 18, 2015 | 11:49 AM
dsnyder586's Avatar
I just did this a month ago- Need to remove the triangle in the corner of the window frame, molding and I removed the control box and motor/mechanism before I could get the window in. (obviously needed to remove the door card, etc.) it went in diagonally. If you could post a how-to while you are doing it that would be great, as I could not find one.
Old Jun 19, 2015 | 02:39 AM
The link to the manual should be with you in your email Thomas. Hope it helps, and yes a +1 on a thread on how to do it in practice would be a great idea for anyone else coming up against this job.
Old Aug 4, 2015 | 03:39 PM
Default Project restarted
Hi, I had to take a break with this project but now I made some progress with the info I received from Steve, many thanks for that.
I'm afraid I didn't notice Dan's much appreciated info until today, glad to hear that someone has done the job, if I succeed I will write some PM on how to do it.
I think Dan has already started it.
msdg137
Sep 16, 2015 06:24 AM
plmmd
Aug 31, 2015 10:07 AM
24ktairman
Aug 30, 2015 10:25 PM
Jandreu
Aug 29, 2015 07:31 PM
dpappyp
Aug 27, 2015 06:31 AM
