rear end banging
Old Jul 3, 2017 | 05:11 PM
Rodster's Avatar
Default rear end banging
My 99 XJ8 is showing signs of her age I guess and is indicating this by lazy changing of gears and sometimes hard bangging, what's actually going on? Most greatfull for any insight here before I head to a fixerupper.
Old Jul 3, 2017 | 05:25 PM
larney's Avatar
Possible A drum issue? Possible trans valve body repair?
Old Jul 3, 2017 | 05:29 PM
Rodster's Avatar
can you elaborate, drum issue, trans valve body...
thx
Old Jul 3, 2017 | 05:40 PM
King Charles's Avatar
thx
Search "A-Drum" here there are several in-depth threads covering it.
Good luck !
Old Jul 5, 2017 | 10:43 AM
nilanium's Avatar
If it's clunking coming from the rear end, and not the transmission, it could be something less catastrophic like the driveshaft jurid couplers, half shaft U-joints, rear subframe bushings, etc. and that depends a lot on how exactly the clunking behaves.
Slow gear changes and banging into gear does sound like A drum though.
Old Jul 5, 2017 | 06:26 PM
larney's Avatar
When my A drum went out I originally thought I got rear ended. When I looked in the rear view mirror and didn't see a car I knew something was wrong. The only warning I had was a couple odd shifts then the BANG. So to me the trans bang sounded like it came from the rear. Any codes? lights?
casper52
General Tech Help
Jan 21, 2021 12:23 PM
dana0330
Oct 17, 2016 11:40 AM
Jul 23, 2007 08:52 AM
Mar 13, 2007 12:07 PM
Feb 4, 2007 12:43 AM
