Rear inside brake light
Old Apr 23, 2011 | 01:47 PM
ant17's Avatar
Default Rear inside brake light
What kind of adhesive must I use for my inside brake light?
It seems to have dropped down from the back window.
tia
Old Apr 24, 2011 | 02:44 AM
SuperSport's Avatar
tia
I simply used Crazy Glue (solid over 1 year so far), but the correct glue is Rear View Mirror Adhesive, found at most auto parts stores. It's quite cheap.
Keep in mind, you need to mark the position of the metal pads, then remove them from your light housing. Glue them into the marked
positions and let set up. Then snap light housing back onto metal tabs.
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
obwoodie
Sep 3, 2015 07:45 PM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
