Rear Shock Mount Bolt Size
Old Apr 29, 2025 | 05:23 PM
X308TheKingCharles's Avatar
Default Rear Shock Mount Bolt Size
Having trouble finding replacement info for the 4 bolts on the rear shock mount plate. I will be changing the rear shocks soon and I estimate that there will be 87.5% chance that I snap a bolt or two off since they are so seized with rust
Old Apr 29, 2025 | 06:36 PM
motorcarman's Avatar
M8 x 1.25mm 'paint clearing bolts' are what Jaguar uses but any M8 bolts will work that are 25mm to 30mm long.
Old Apr 29, 2025 | 07:06 PM
thank you Motorcarman - I appreciate that. Best case scenario I can reuse the original, worst case scenario I’ll have the tap and die set handy 😅
Old Apr 30, 2025 | 08:59 AM
I have never had to replace the bolts, I just re-use them but rust is not a big problem here in North Texas.
Old Apr 30, 2025 | 09:53 AM
I would love to work on a car with no rust. Unfortunately the solution used here in NY seems to be designed more so to aid in corroding iron than melting the snow. The trickiest part here is being patient with penetrant and heat.
Old Apr 30, 2025 | 10:32 AM
RandyS's Avatar
Snow and ice melting at the expense of increased metal oxidation
has never seemed a wise solution in my book. However, there does
not seem to be another solution which would be effective without
that effect. My own solution is not to drive the Duchess in these
conditions, preferring a more expendable vehicle.
Old Apr 30, 2025 | 11:41 AM
Jhartz's Avatar
gentle heat and a blue crayon . . .
Old May 1, 2025 | 02:00 PM
you are definitely correct. But the duchess is such a head turner!
97XJR-Flausa
Jan 23, 2019 10:36 PM
dude1579
Dec 27, 2017 12:56 PM
dave114
Mar 14, 2015 04:48 PM
randyb
May 16, 2013 12:15 PM
aliastel
Jul 16, 2012 03:32 PM
