Rear wheel bearing replacement
Old Aug 20, 2015 | 03:30 PM
Freebird's Avatar
Default Rear wheel bearing replacement
Hi All
My nearside rear wheel bearing has a bit of play and makes a bit of noise too. Reading up on it, there are shims between the bearings and it looks quite a task to set the endfloat up.
is it difficult in reality? Any advise most welcome as always.
Glen.
Old Aug 20, 2015 | 08:19 PM
motorcarman's Avatar
Install NEW bearings and use the original spacer/shim setup!!!!!!!!!!!!!!!!!!!!!
DONE.
bob gauff
Old Aug 21, 2015 | 01:06 AM
Don B's Avatar
Hi Freebird,
+1 on Bob's advice.
I've done all the wheel bearings on both of our XJ40s and never had a problem reusing the shims/spacers on the rears with new bearings and never had to mess with endfloat.
Below are links to photos of the rear wheel bearing replacement process on our '93 XJ40, which is very similar to the X308 (the bearings and seals are the identical parts with the same Jaguar/SKF/Timken part numbers):
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
Old Aug 21, 2015 | 03:20 AM
Freebird's Avatar
Brilliant, guys. Thanks.
Old May 9, 2021 | 11:43 PM
Putter03?'s Avatar
Default Leading the blind
Thanks for directions on the wheel bearings I will keep you posted on my progress, I think I see the light
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
JaguarXKR
Sep 6, 2015 11:47 AM
TC Johnson
Aug 29, 2015 08:55 PM
