Removing rear driveshaft donut
Old Jun 20, 2018 | 11:13 AM
zagamuffin's Avatar
Default Removing rear driveshaft donut
as I can’t tow my xj8 to the gearbox shop as it’s an auto I’ll need to drop the rear driveshaft joint to allow it , for all the bolts out but the donut is secured with the shafts center shaft , do I need to drop center bearing to get the rear flange room to pull away from the diff
sorry biut all all the QA. It I’m new to Jags ....
Old Jun 20, 2018 | 01:11 PM
avern1's Avatar
Your Jag needs to go on a flat bed tow vehicle. Any other towing method will cause damage to the suspension. You should not have to remove the drive shaft at all. Just shift to neutral and they can winch it on using the towing eye. Absolutely do not allow chain hooks to the underside.
Old Jun 20, 2018 | 02:35 PM
zagamuffin's Avatar
Hi Avern ,
damage to sispension ??, you’ll have to explain that please as can’t get my head around how the suspension knows if it’s poeered or not
I do understand that autos can be damaged as the box is spinning due to diff feedback but no pump is running so oil starvation can occur
I disconnected drive shaft to isolate auto box from drive source
cheers for the feedback
Old Jun 20, 2018 | 06:21 PM
avern1's Avatar
Jaguar does not have anything under the vehicle for an attachment point of tow hooks. The winching onto a flat bed will not damage the transmission. Towing the vehicle with the wheels on the ground for a distance can damage an automatic transmission. I am not positive that applies to the ZF but does on the older GM and Ford transmissions.
Winching on with tow chain hooks from the front or rear will damage bushings and linkages that are not designed for that stress.
Jaguar has a tow hook location front and back for a flat bed recovery truck.
Old Jun 20, 2018 | 11:47 PM
Daim's Avatar
You could use the two front strap brackets mounted on the rear of the front subframe-body bolts...
Old Jun 21, 2018 | 01:47 AM
zagamuffin's Avatar
so what im doing ive done for years and maybe not explaining corectly,im going to tow the jag with another car @ 10 miles to the gearbox repair center using a bar connected between tow cars and jags front and rear tow eyes under front and rear bumpers respectively.
ive disconnected the driveshaft as you say correctly you cant tow an automatic normally but as i've isolated the gearbox from the road wheels its ok....
Old Jun 21, 2018 | 04:49 AM
Daim's Avatar
Sure, no problem. But you are actually able to tow it in N. BUT no more than 20 miles at 20 mph. That is as it is written down for the Audi S8, RS6, BMW 7 Series and others with the same 5hp24 (if not the Mercedes tranny).
Old Jun 22, 2018 | 06:28 PM
grantorino62's Avatar
If it's going to the trans shop why worry about damaging it by towing it? It's already damaged, correct? Towing 10 + miles should not do further damage.
AllanG
Feb 4, 2014 07:21 AM
AllanG
US Lower Atlantic
Feb 3, 2014 11:08 AM
xcxre8
Nov 13, 2011 11:40 PM
swoop22
Oct 31, 2011 03:19 PM
cincinnati
Oct 31, 2011 03:12 PM
