removing steering wheel
Old Jun 29, 2013 | 01:53 AM
osyris's Avatar
Default removing steering wheel
Does anyone have info on removing the steering wheel from a 1999 x308?
It seems is have a loose wire on the auto portion of the indicator stalk that I need to get to.
I cannot locate info on steering wheel removal, JTIS dosnt want to run on win 7
'best regards
Peter
Old Jun 29, 2013 | 08:27 AM
motorcarman's Avatar
Disconnect battery, remove airbag, remove fastening nut, pull steering wheel off.
bob gauff
Old Jun 29, 2013 | 08:45 AM
jaguar jon02's Avatar
pretty simple undo the 4 torx bolts in rear of wheel housing. air bag lifts off, undo wires . set aside and take off nut in center of wheel. lift off. replace in backwards order. total of 5 steps
Old Jun 30, 2013 | 05:00 AM
jimlombardi's Avatar
Here is an illustration (from JEPC - Jaguar Electronic Parts Catalogue) showing the Steering Wheel (and the bolt that holds the Steering Wheel on - reference number 3).
https://www.dropbox.com/s/htj1cr6syk...lustration.jpg
Here is information from IanG post in this other forum thread
https://www.jaguarforums.com/forum/x...g-wheel-69804/
It's an easy job to remove the wheel and you won't damage it.
My steering wheel was held on with a 15mm bolt, and you might need someone to hold the wheel whilst you turn it. You don't need a wheel puller, it should come off the spline easily.
He had links to photos of the removal, but they are no longer worked - invalid web address.
I sent Ian an email, asking him to email the photos and I will put them on another download server, then I will create a new post in the thread to make them available to forum members.
Here is a PDF extract from the JTIS software - Driver Air Bag R&R
XJ (X308) Driver Air Bag Module R&I N.pdf
Email me with screen shots of the issues you are having with JTIS running on your Win7 PC - also include what version of Win7 you have (32 or 64 bit).
Jim Lombardi
Old Jun 30, 2013 | 11:27 AM
Tirefriar's Avatar
Just make sure you don't turn on the ignition to second position or you may have to reset an SRS light. Reason being if the air bag is disconnected and the SRS system is turned on the self diagnosis will detect a break in the system and trip a code
dsnyder586
Dec 29, 2024 07:39 PM
rusty37
Apr 5, 2020 07:40 PM
PMKimpton
Aug 3, 2019 08:22 PM
sogood
Sep 15, 2015 07:35 AM
AL NZ
Sep 4, 2015 08:39 PM
