Replace Third Brake Light Bulb in 2001 VDP?
Old Mar 26, 2011 | 11:10 PM
SirJag's Avatar
Default Replace Third Brake Light Bulb in 2001 VDP?
Has anyone done it... or is it the LED type that is not worth trying to replace (so I've heard).
Thank you,
SirJag
Old Mar 27, 2011 | 01:10 AM
plums's Avatar
5 wedge bulbs.
usual North American equivalent #168 or 5W5
r&r instructions are in the vehicle maintenance booklet
Old Mar 29, 2011 | 07:08 PM
jimlombardi's Avatar
Default High Stop Light bulb R&R PDF extracted from JTIS CD
Hi
Here is a PDF file I created from JTIS CD. Shows how to remove and replace the bulbs in the rear high stop light.
To get the best viewing of the pages in this file, use Full Screen Mode option in the Window menu dropdown. While in Full Screen Mode, click any where on the screen and advance to the next page (there are 3 pages). Use the ESC key to return back to the normal display:
2001 XJ high stop lamp bulb R&R.pdf
It looks like an easy task to change the bulbs.
Jim Lombardi
Old Mar 29, 2011 | 07:24 PM
Blackbeard's Avatar
Smile Both my XJ8's
I discarded that huge rattling annoying third brake light with this aftermarket LED light with no problems...
LED THIRD BRAKE LIGHT - JCWhitney
Old Mar 30, 2011 | 04:20 AM
SirJag's Avatar
Originally Posted by jimlombardi
Hi
Attachment 9060
Jim Lombardi
Once again, my "Uncle Jag" comes through with step-by-steps. Thank you, Jim! This is easy enough even for me to do.
<HANDSHAKE>
SirJag
Old Mar 30, 2011 | 04:24 AM
SirJag's Avatar
Thank you! I might end up doing this, as I never saw mine actually work... it might be more than simply "bulb dead." What kind of adhesive did you use to stick it up... or does it have peel and stick strips?
SirJag
SirJag's Avatar
Originally Posted by plumsauce
5 wedge bulbs.
Thanks for the bulb numbers, PlumSauce!
SirJag
Old Mar 30, 2011 | 04:56 AM
plums's Avatar
BTW, the #168 is known to be good, the 5W5 is a newish cross reference number. The #168 also fit the side markers and possibly some of the interior lights, so you might want to get a box of ten.
Now, the #912 is 13 watts over the 5 watts of the #168. It has a bigger globe, but fits in the space no problem and has the correct base. Increased heat dissipation is not really a concern because they aren't lit for very long.
Before someone starts ranting about brighter brake lights ahead of them - that's the point, stay farther back.
BTW, about the LED thing ... if you've never seen the bulbs lit, then you still have to make sure the wiring up to the light works, so it won't solve that problem ... and then if you have tint it probably won't match the cutout.
Old Mar 30, 2011 | 12:25 PM
Blackbeard's Avatar
Smile The outside...
SirJag
Comes covered with a peel and stick. Took out the whole awkward Jaguar light, tapped into the wire that it was hooked up to and worked in both XJ8's without rattling, brighter light, cheap fix.
Old Mar 30, 2011 | 12:34 PM
ixj8it's Avatar
What does that look like from the inside?
Old Mar 30, 2011 | 06:04 PM
Blackbeard's Avatar
Smile From...
The inside it is much smaller than the unwieldy rattle box that Jaguar designed, much more out of the way.
Old Oct 4, 2019 | 04:27 PM
justdANDY's Avatar
Default high brake light in op.
lower brake lites are good. the high light is off. check for 12 Volts at the harness plug. no juice. where to next?
Doberman_Fan
22
Dec 24, 2019 06:21 AM
rudelover2
Sep 11, 2015 08:53 PM
Oliver9218
Sep 3, 2015 05:33 PM
tonydbaker
Aug 30, 2015 11:02 PM
