Replaced with simple performance UK shocks by GAZ
Old Jun 3, 2023 | 02:03 PM
vincent661983's Avatar
Default Replaced with simple performance UK shocks by GAZ
My R's shocks finally gave up after 20 plus years and bushings are all wore out.
I went for the adjustable shocks by simple performance UK.
In mid setting. Thr shocks take the back NY road pretty well.
Old Jun 3, 2023 | 10:24 PM
Z07Brandon's Avatar
How is the car's height compared to stock?
Old Jun 4, 2023 | 11:23 PM
Old Jun 5, 2023 | 06:56 AM
Z07Brandon's Avatar
Cool. But I meant how does the car sit, in relation to being on the stock shocks. Do you get me?
Old Jun 5, 2023 | 09:02 AM
Hi, Brandon. I got your question but I didn't have a chance to take a closer look until this morning. by eye balling it, the car sits up a little higher in the rear I think because the shock bushing Simply Performance UK supplies me.
My Mechanic told me if I were using the stock spec/ OEM bushing, the car should ride at the same height.
Old Jun 6, 2023 | 04:19 AM
markdpeter's Avatar
We’re you replacing CATS shocks? If so, did you need to make any programming changes?
Old Jun 6, 2023 | 01:36 PM
RandyS's Avatar
Is there any particular reason you selected the adjustable shocks as a replacement?
Old Jun 7, 2023 | 10:22 AM
mine is a Non-CAT version X308 XJR
Old Aug 13, 2025 | 07:27 AM
Alex_O's Avatar
I’m interested as well with those GAZ shocks, would you recommend it after you had time to test it ?
Old Aug 21, 2025 | 02:33 PM
Because they are adjustable..why not
After near 2 years..yes I would recommend
Old Aug 21, 2025 | 03:01 PM
RandyS's Avatar
After two years, did you make any adjustments on these adjustable shocks?
Old Aug 22, 2025 | 03:49 AM
Alex_O's Avatar
I have the CATS version, I won't replace with the adaptative ones, but still hesitating to go GAZ or Bilstein B4 sport, since they're more OEM.
Would you have any insight on that aspect, the GAZ one can lean on the confort side, or they're really made to be sporty?
cs81srq
Aug 12, 2023 07:42 AM
pcolapacker
Apr 18, 2021 09:34 PM
weldboy
Jun 26, 2012 11:14 PM
FastKat
Jun 19, 2012 02:04 PM
Carthage4404
Jan 13, 2011 10:25 PM
