Replacing the Bumps Stops on my xjr with smaller ones
Old Oct 2, 2018 | 12:20 PM
Dirtboy Nay's Avatar
Default Replacing the Bumps Stops on my xjr with smaller ones
Hi Ladies and Gents, I want to replace the Bumps Stops on my 2003 XJR with smaller ones. I have a 2003 Jaguar XJR R1 with 8 x 18 ET33 BBS Milan Wheels. I recently Purchased 9 x 18 ET35 BBS Milan Wheels. The 275/40ZR18 rubbed on the Rear Bump Stop MNA3750AB. I was advised to replace the bump stops with the Bump Stop from an earlier model XJ40 XJ6. Here is the part # MNA3750BA. As anyone on the forum do ne this ? If so, is it a straight forward bolt on ? Or does it requires modification ? What do you think ?
Old Oct 2, 2018 | 05:52 PM
grandell's Avatar
There is an alternative bump stop for R1 equipped cars, but I can't find the part number. The common solution is usually just to cut down the existing bump stop, making it narrower, so that it doesn't rub on the wheel
Old Oct 2, 2018 | 05:59 PM
ericjansen's Avatar
Yes, just "halve" the ones you have if you can't find replacement ones, you loose 2 bolt holes but it seems not a problem for mine.
Old Oct 2, 2018 | 07:19 PM
Thanks Grandell and Ericjansen I appreciate the feedback. Halving the bump stop out seems pretty straight forward. Eric do you have a front view pic of the halve out bump stop ? Here is the pic of both MNA3750BA And MNA3750AB bump stops . What do you all think ?
Old Oct 2, 2018 | 07:37 PM
ericjansen's Avatar
I only have one from the stop installed.
I just used an angle grinder with a thin cutting wheel (lacking a lint saw), and cut off the protruding steel part, along the edge of the rubber.
It is a bit of a mess, as the rubber is vulcanized on the steel frame, and there is no way not to cut in it ( a lint saw will do much better there).
Quick and easy job though.
Old Oct 3, 2018 | 10:16 AM
Jhartz's Avatar
Wow: your wife lets you park your car on an oriental rug. Wow! Bought one in Hong Kong forty years ago: almost that long before she would let me walk on it.
Second one got it in Formosa. Looked a lot like yours. Still can't walk on it without getting my *** chewed . . .
TenPercenter
17
Nov 8, 2023 04:16 PM
caferacer
Mar 24, 2017 07:16 AM
jsupstarz
Nov 27, 2012 08:36 AM
WaterDragon
Oct 8, 2012 12:54 AM
