Replacing the Upstream O2 Sensors
Old Aug 12, 2020 | 04:30 PM
Myfirstjaguar's Avatar
Originally Posted by Highhorse
You may need to drive it a bit for it to recalibrate, should only need to go up to 50 miles.
You may want to review this write up... https://www.jaguarforums.com/forum/x...cement-195018/
Thanks Highhorse I should have mentioned I did take it for a 50 mile run the same night and it has since done another 55 or so of mixed driving but it's still the same. I will have a look at the link and make sure there's nothing I've missed out.
Thanks again for your quick reply
Old Aug 13, 2020 | 10:16 AM
Hi all, I've just got hold of a known working 2nd hand unit from a trusted seller so will repeat the process and let you all know the outcome. if it does turn out to be a bad/fake o2 sensor that i was sold, i will post a link for you all to avoid.
Old Jul 20, 2021 | 08:36 PM
wss25's Avatar
My Sensor 1 Bank 2 is sending an error code. Should I replace the other side too or just this one.
Old Jul 21, 2021 | 07:03 PM
Highhorse's Avatar
No need to...personal choice.
Old May 30, 2023 | 05:09 AM
RogerFromChicago's Avatar
Jaginblack, you're my hero! With no Chilton's manual for this, I was about to call a mechanic when I found your post. No engine lights today thanks to you!
In my case, the upstream sensor was clocked in such a way that the rachet handles and breaker bar didn't work. Moving the crow's foot to 9:00 I was able to hit it with a hunk of broom handle with a rubber mallet to break the sensor free. This may help otheres, thank you again!
Poet
Feb 7, 2025 02:18 PM
04Xjrsteve
May 7, 2019 04:06 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
dmatthewman
Sep 30, 2015 10:10 AM
