restricted performance/failsafe problem now with OBD-II codes
Old May 8, 2008 | 02:24 PM
erobbins's Avatar
Default restricted performance/failsafe problem now with OBD-II codes
I got a reader from autozone, and it pulled these
P0171
P0174
P1642
P1000
from my 2000 XJR
so, I'm looking for guidance fuel pump/filter maybe?
Old May 8, 2008 | 03:28 PM
erobbins's Avatar
Default RE: restricted performance/failsafe problem now with OBD-II codes
just checked the intake pipe and seal with the throttle body, both good, couldn't find a leak with my eye anyway. MAF was just replaced, which fixed my hesitation and poor performance issues
Old May 8, 2008 | 06:05 PM
FactoryJaguarTech's Avatar
You have a vacuum leak of some sort. The code reader you bought, does it just read codes, or can you look at some live data? If you can, look at the ltft and stft on both banks. Look at them at idle, then carefully under a heavy acceleration see what they read, may be better to have someone else drive.
On the R there are many places for the vacuum leak. Look at fuel trims first, then let us know. Also, clear the codes before checking that.
Old May 8, 2008 | 06:58 PM
JagtechOhio's Avatar
Intercooler O ring seals?
Old May 8, 2008 | 07:53 PM
Rock Meathammer's Avatar
What's the CAN circuit malfuntion code for? (p1642)
Old May 9, 2008 | 01:14 AM
erobbins's Avatar
ORIGINAL: FactoryJaguarTech
the code scanner is just a loaner from autozone.. only scans, doesn't monitor live unfortunately.
since I removed/reseated the throttle body/intake manifold junction earlier today, I haven't had the problem again, and I've driven probably twice as much as I had when it was cropping up earlier. that doesn't mean it's fixed of course... but it could have just been loose and letting air in. Should there be any grease on that seal? I assume not, looks like it just fits dry. I will talk to someone local and see if I can get them to read some data for me
thanks!
Old May 9, 2008 | 01:15 AM
erobbins's Avatar
ORIGINAL: JagtechOhio
the joints between the SC output and the intercoolers? they look good, I think.. the seals seem to be correctly in place
Old May 11, 2008 | 05:37 PM
erobbins's Avatar
got failsafe mode, code P0121
I saw there was someone else who had a similar problem which was the result of the metal in the TPS sensor pins being mismatched.. one side was gold and the other was tin.. not sure where that sensor is to check the pins
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
PMKimpton
Aug 3, 2019 08:22 PM
OkieTim
Sep 2, 2015 12:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
