security locking module not working (2 buttons on fob key not working)
Old Apr 17, 2017 | 06:34 AM
Martyn Musch's Avatar
Default security locking module not working (2 buttons on fob key not working)
hello,
Update on previous post: ids says: communications failure with the security locking module, i cant lock unlock on the fob, only with the key. is there a fuse or relais for this sec. locking module?
thanks guys!
Old Apr 17, 2017 | 07:47 AM
Sean B's Avatar
Martyn - read up on the term "hard reset" - this sets the car back to factory settings by disconnecting the battery. This is the first thing you should do...
Next I'd suggest seeing if the rear brake lights function correctly - they run through and are controlled by the security locking module and a sure sign if the module is dead.
Also when posting make sure you include the model and year so wiring diagrams can be consulted, there's differences in years.
Old Apr 17, 2017 | 10:49 AM
Thanks! Performed a hard reset but it didnt help, my braken light left and right are good, any other tips?
Old Apr 17, 2017 | 11:06 AM
PROBLEM SOLVED! Saw a raw wire on the control unit, repaired it and solved! Thanks!
Old Oct 5, 2018 | 04:08 PM
Angela-XJ8's Avatar
Which control unit? Where is it located?
I just replaced my fob battery and none of the buttons work. I followed the procedure to reprogram
Old Sep 3, 2022 | 08:51 AM
amal58's Avatar
My X358 keyfob suddenly not working.. replaced the battery didn't help, try to repair it by inserting the key while holding up high beam and then press high beam five times, then press any button five times no response. What are possible causes? Thanks.
Old Sep 3, 2022 | 09:03 AM
amal58's Avatar
Second question, anybody has experience to make a second keyfob based on a non-genuine spare bought from e-bay? I have only one key and thinking about creating a spare. Thanks.
Old Jul 23, 2023 | 11:21 AM
ultrageoff's Avatar
Default Just buy a replacement key fob and join your old key to the new buttons
My tip, buy a new X type key fob on the bay of ee, 433MHz for Europe, something else for USA/Canada. Split them as if going to change the battery (YouTube vids), attach the old 'key' front to your new 'buttons' back part and pair as per this video:
. WD40 your ignition lock to free up the metal flap that sometimes sticks where you put the key in (do this!! As may not pair otherwise!!!), do as seen in the video reasonably quickly (not slowly). Replacement key fob is indistinguishable from original, works perfectly. Cost approx 16 euros and easy to do.
Old Jul 24, 2023 | 10:54 AM
vincent661983's Avatar
why dont you try to ask your own X350/X358 group but instead of asking us at the X308 group? we have very different cars here.
Old Jul 24, 2023 | 04:01 PM
ultrageoff's Avatar
Default Sorry, wrong place
Sorry Vince! I must have been very sleepy yesterday. If any mods know how to move my post to the X types forum, please do that. I've been enthusiastically broadcasting my cheap solution everywhere that googles for 'Jaguar X type remote key fob not working', didn't see this was an X305 thread. Anyway, if buying a new key and putting a new 'remotes' half onto the old 'key' half and then pairing to the car works for anyone here, I'm happy.
dcarlo
Jun 10, 2021 09:45 AM
JagJoe80
Apr 21, 2018 06:34 AM
ixj8it
Nov 7, 2012 11:45 PM
petemate612
Jul 22, 2012 03:16 PM
krskonin
Jul 15, 2009 05:40 PM
