Shifter plug removal ?
Old Feb 2, 2019 | 06:45 PM
King Charles's Avatar
Default Shifter plug removal ?
Anyone know how to get this torx bolt/plug out I've tried numerous sizes of bits to no avail. If not what is the part #. I'll just buy another as my replacement used unit did not come with one.
Old Feb 2, 2019 | 09:07 PM
M. Stojanovic's Avatar
I don't think there is a special tool for this but you can easily make one. The manual says you can use the key (as a kind of flat screw driver) to remove the plug but I haven't tried it (does not seem really possible). A flat screw driver of suitable size can probably do it.
I made my "special tool" out of a Torx bit. I do not now remember its size but its diameter over two opposite peaks is 6.5 mm. All I had to do is grind down a bit (Dremel) the valleys of the Torx to match the actually "non-torx" socket in the plug. I also inserted the bit into a nice handle (a choke knob, leftover from my ex Triumph Stag).
Old Feb 2, 2019 | 09:12 PM
Yes & thanks, the engineering with this a bit counter productive for sure.
Old Feb 3, 2019 | 10:49 PM
Anyone have a part # ?!
Old Feb 10, 2019 | 07:23 AM
aquifer's Avatar
The part number is CCC5589. My car did not have one when I got it, so I ordered it a few years ago. They are available, or were at that time anyway. A torx bit or the tip of the key works to remove it.
Old Feb 10, 2019 | 08:05 AM
Yes I have one on the way.
https://www.ebay.com/itm/JAGUAR-Genu...-/161588957477
Old Feb 15, 2019 | 07:12 AM
tommo1471's Avatar
I removed mine yesterday with a flat headed screwdriver
rjcl004
Dec 28, 2013 09:38 AM
tony1963
Jul 28, 2012 03:26 PM
benebob
Sep 15, 2010 09:12 AM
MyfirstJag
Sep 7, 2010 09:45 PM
