Side mirrors housing remove/replace?
Old Jan 29, 2019 | 03:15 PM
3timejag's Avatar
Default Side mirrors housing remove/replace?
Anyone versed on the removal of the entire side mirrors on a 98-03 XJ8? Videos, or how-to would be great!
Many thanks in advance!
Scott
Old Jan 30, 2019 | 03:16 AM
Lady Penelope's Avatar
based on earlier X300
The chrome pieces come off without the whole unit and don't need to come off if removing whole assembly
Buuuuuuuuuuut
No need to remove interior door side panels
with a plastic putty knife carefully pry off the fwd widow corner plastic triangle
It has plastic hocks on the inside you will probably break in the process but is also glued in place with anti rattle glue that can be reused
There is one nut about 15 mm and the threaded shaft on the mirror won't spin
The electrical connector is tucked into the main rubber seal so just tug out
Old Jan 30, 2019 | 09:27 AM
3timejag's Avatar
Mine is an X308 (2003 XJ8), same procedure?
Old Feb 2, 2019 | 03:19 PM
cliveb's Avatar
I'm interested in this procedure also, my passenger (right side) mirror is a bit loose and I want to tighten it.
I'm afraid of breaking the plastic triangle piece on the inside of the passenger door.
Clive
Old Feb 2, 2019 | 03:52 PM
3timejag's Avatar
Well, if you hear of the procedure, please pass it on, I’ll do same!
Maciek
Oct 24, 2017 11:18 PM
akubeta
Sep 26, 2013 06:38 PM
djpxk8
Sep 30, 2011 09:59 PM
