Sporadic Windshield Wipers
Old 06-30-2019, 11:27 AM
shuyghe's Avatar
Default Sporadic Widnshield Wipers
I have a 1998 Jaguar XJ8L and the wipers come on and when I try to turn off, they keep running then stop randomly on the windshield. Not back to the home location. Anyone have a similar problem and any suggestions?
Old 06-30-2019, 01:05 PM
GGG is offline
Received 16,827 Likes on 12,179 Posts
Steve,
I've copied the question from your Intro thread to X308 forum. Members here with the same model will be able to help.
Old 06-30-2019, 01:55 PM
Carnival Kid's Avatar
Received 1,008 Likes on 613 Posts
Not a guaranteed solution, but sometimes the wiper relays can be the problem. There are two of them, located under the hood just behind the driver/left headlights. (I think this is true thru the whole 1998-2003 range)
They are the same part number, and one controls On/Off, the other Fast/Slow. One may be faulty, or just have corrosion on the contacts. You could try removing them both for inspection.
I'm pretty sure the part number is LNA6706AA, and they are available online
Follow this link
Amazon Amazon
Old 06-30-2019, 03:23 PM
shuyghe's Avatar
Thanks..I am going to give this a try. .will let you know if this resolves the problem
Old 07-05-2019, 02:27 PM
shuyghe's Avatar
Default sporadic windshield wipers
It was not the relays. Anyone know what else can be the problem?
Old 07-05-2019, 02:35 PM
Old 07-06-2019, 09:26 AM
nigelmay's Avatar
I suspect that it could be the Body Processor Module playing up. It is located behing the glove box. I had a vey similar issue, with wipers and other stuff misbehaving. The problemm was cured by running an additional earth from one of the the BPM securing bolts down to the gearbox.
Old 07-09-2019, 08:57 AM
yeldogt's Avatar
Did you replace with new ? This was common failure back in the day .. both of mine had them replaced.
Does anything occur when you wiggle the control ?
Kirk Gresham
02-03-2014 03:48 PM
MonkeySix
04-08-2013 12:35 PM
hackman
11-15-2011 09:52 PM
Quick Reply: Sporadic Windshield Wipers
