Starter issue?
Old Jul 26, 2020 | 02:11 PM
edreddy's Avatar
Default Starter issue?
Took this video of the car - to me, it sounds like the starter isn’t engaging, just spinning.
Anyone else having this issue?
Old Jul 26, 2020 | 03:11 PM
Addicted2boost's Avatar
While someone is cranking the engine, carefully look at the drive belt and/or pulleys with a flashlight. If the pulleys are moving, then it’s not your starter. To me however, it sounds like the engine is spinning over.
Old Jul 26, 2020 | 03:58 PM
edreddy's Avatar
the engine belts are spinning albeit slowly. Posted code P1111 and when I cleared the codes P1000.
Old Jul 26, 2020 | 04:12 PM
Carnival Kid's Avatar
Code P1111 means there are no current error codes detected by the engine control computer (ECC)
You cleared the codes, of which there were none, and so you reset the ECC and so now it has to complete a full recheck of the system, which is what the code P1000 indicates. Once it has completed a check of the system and found no error codes, which may take 100+ miles, it will then display the P1111 again.
Old Jul 26, 2020 | 04:19 PM
The engine sounds to be turning to me, I think I would suspect a failing battery. The ECC likes to have full voltage from the battery (12.6volts or more) in order to start, check the voltage at your battery.
Also check the fuel pressure by removing the cap on the Schrader valve on the fuel rail and depressing the valve as you would on a bicycle tire, with the ignition on you should get a healthy spurt of gasoline out of the valve (have a clean rag handy).
Old Jul 26, 2020 | 05:27 PM
edreddy's Avatar
if I don’t try starting it and leave the ignition on, I do not get any pressure, but if I try to start it then I get gasoline squirting out.
I almost had it started, but then it died. I’m suspecting it’s a fuel issue, and #1 suspect is the fuel pump.
Old Jul 26, 2020 | 06:14 PM
roycej's Avatar
Check the fuel filter.
Old Jul 26, 2020 | 06:15 PM
edreddy's Avatar
I replaced it last year - good idea though.
Old Jul 26, 2020 | 06:46 PM
You should have fuel pressure with the engine off and the ignition on......I forget exactly what it should be, 42psi seems to ring a bell. And then with the engine running it should be around 38psi as I remember.
Harbor freight has a very economical fuel pressure gauge set for $25 bucks. (just $20 bucks if you use their 20% off coupons)
https://www.harborfreight.com/fuel-i...ter-62623.html
But first..........did you check the voltage at your battery?
Old Jul 26, 2020 | 07:33 PM
edreddy's Avatar
Ok, it’s weird.
I changed out the relay (I have extras) and...... my brother in law was at the helm, we tried starting it a bit more, he made a comment about Marty McFly and starting the DeLorean, hit his head off the steering wheel in exasperation and... it started.
W.T.H.
Drove it around, filled up the gas tank, drove home. (Sigh)
I’m going to check the old relay. Thanks for the tips guys. Appreciate it.
Ed
tilbury
Dec 2, 2016 07:33 PM
dhatfield12
XJ40 ( XJ81 )
Sep 12, 2016 11:22 PM
jnporcello
Apr 22, 2015 04:04 PM
Spikepaga
Jun 14, 2014 12:32 PM
maikal_0011
Nov 5, 2011 11:18 AM
