Hi guys, I have a 2001 jaguar xjr and have had a massive headache starting the car. It seems to only start if I turn the key all the way and then go under the car and bridge the starter with a piece of metal. After that car runs fine but wont start back up if I turn it off.
I have checked and switched relays, fuses, exciter ring, ground strap and cleaned the connections. The gear selector does move freely when the key is on.
Help mate's!
Before you start tearing things apart, try another ignition key. I've started to notice that the key I regularly use, sometimes doesn't start the car right away, I have 3 keys, not including the valet, 1 doesn't work at all, 1 works intermittently and the other works just fine.....worth a try.
oops I didn't see that you fixed the problem, nice looking car.
Clive
They will send you a sample swatch to see color match and I assume its not the best leather as they would use the better shop material for production of the actual
Just guessing
They take some time to condition with some lotion and stretch out to form better
