Supercharger oil
Old Jun 24, 2013 | 02:52 PM
Winks's Avatar
Default Supercharger oil
I will be replacing my supercharger oil in the next few days. From going through old threads I had learned that the GM# 12345982 was supplied by Eaton and is identical to the Jaguar stuff but without the $60 a bottle price tag (called the dealer to ask). Unfortunately, GM no longer uses part number 12345982 and has a new blend with a new part number 10953513. Is this new GM stuff still acceptable for my car? or is there a better alternative.
Old Jun 24, 2013 | 03:30 PM
vincent661983's Avatar
if GM has a new blend for the same old vehicles, I would assume it should be compatible otherwise how those GM car owners find their SC oil anymore?
Old Jun 24, 2013 | 04:27 PM
Winks's Avatar
I don't know the details of the new blend, its just what I was told by the parts guy at gm that sold it too me. I assumed it was the same just with a new part number, but I would rather know for sure before I put it in the Jag
FYI the bottle does say made in the USA (don't know if that helps)
Old Jun 25, 2013 | 03:07 PM
plums's Avatar
It's fine.
I don't even use a part number. I just find a random GM parts counter and ask for two bottles of SC oil. They sell so much of it that the guys usually just reach into a bin without looking.
Old Jun 25, 2013 | 05:13 PM
Michael Star's Avatar
This is what I used pn# 12345982
Old Jun 25, 2013 | 07:01 PM
Winks's Avatar
ok I will give it a shot. I cannot believe the price as the jag stuff is $60 a bottle and the GM is $4.50 a bottle....
Old Jun 25, 2013 | 08:38 PM
TN8Shooter's Avatar
Used the GM stuff in mine and it's seems to be just fine.
Old Jun 27, 2013 | 08:34 AM
Winks's Avatar
Extracted the oil yesterday and it was dark. Glad I did the oil change and she is running like a top with the gm stuff. We will see what the future holds.
Old Jun 27, 2013 | 10:34 AM
TreVoRTasmin's Avatar
How did you evacuate it? I've tried numerous ways and can't get past the "bend" in mine right after the fill nut.
Old Jun 27, 2013 | 11:56 AM
still remember the smell of that used oil, like the rotten pork, yakkk
Old Jun 27, 2013 | 12:03 PM
Mine was off the car so I dumped it out. Others have used a small piece of tubing (air line for an aquarium) and a syringe.
Old Jun 27, 2013 | 12:57 PM
No workie for me, can't get it to go down past. Hoping someone has a solution that works.
Old Jun 27, 2013 | 02:28 PM
Check out this thread
https://www.jaguarforums.com/forum/s...ics-faq-75585/
Old Jun 27, 2013 | 03:26 PM
Winks's Avatar
The stuff smells rancid when it comes out. The way we go it extracted was with a vacuum based extractor hooked up the an air line, to that we had a few reducers and smaller pipes until we were able to get the majority of it out. You will hit a sweet spot where the stuff just comes out real easy. Don't be afraid of moving the small tube around in there and if you are gentle there should be no problems.
Old Jun 27, 2013 | 06:07 PM
Honestly, I must have a different set up as an educated man who has no trouble doing nearly anything to a car there is no way I could get an 1/8" line in there and get it turned . I don't even think I have an 1/8" of an inch opening at the 90 degree bend. No amount of reading threads has done it nor has using any aparatus that has been suggested. Is it just a casting that wasn't cleaned up as well?
Old Jul 3, 2013 | 08:43 AM
Winks's Avatar
I don't know if its just me being paranoid, but I have noticed a bit of a whistle noise coming from the engine bay under hard acceleration. I still have that wonderful supercharger whine but, I also notice the whistling sound similar to that of a of a turbo noise when they spool up. Is this normal?
Old Jul 3, 2013 | 10:21 AM
Winks's Avatar
Think I found the problem. Popped the hood and found an animal nest that was built up with a mixture of grass and my hood and firewall insulation under the air box. The car was only parked for the weekend and the animal ripped up the insulation, I am furious. Fortunately, I see no damage to any wires or hoses.
silkcat
Jan 18, 2025 04:29 AM
mrplow58
Jan 21, 2024 05:53 AM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Scarecrow
Mar 28, 2016 03:17 AM
duecedriver
Dec 25, 2015 11:47 AM
