Swap engine to newer year 1998 to 2000 xj8
Old Jun 23, 2022 | 11:25 AM
Dog_Man's Avatar
Default Swap engine to newer year 1998 to 2000 xj8
Hello all,
Been awhile since i have been on here or had time to work on my car.
So my question is can you swap from an engine from a 2000 xj8 to an 1998 xj8 if you change the engine module?
Old Jun 23, 2022 | 02:45 PM
motorcarman's Avatar
You need to USE AJ26 engnes. (1997/98 XK8 or 1998 XJ8)
Plenty of info on the forum. (beaten to death)
Old Jun 28, 2022 | 05:47 AM
RandyS's Avatar
There were some big differences between the two.. One of the most significant was the variable valve timing: from the two-stage variable cam units
to the continually variable cam timing design. The injectors are air shrouded and seem to atomize the fuel better with a larger number of holes. however
the only real benefit from this change was getting the vehicle through the state emissions inspection. The pistons have larger cut outs which accommodate
the 8 deg earlier intake valve opening, even though these do not seem to be present on 3.2 and supercharged cars. The AJ27 has the 3 angle valve seats
and would seem to flow a little better but in reality, I don't really see that it made much of a difference. Also, the intake cam period changed a bit from 240 to
230. The coil packs are different with the AJ27 having
four-wire coil packs where the AJ26 had two-wire coil packs.. When you look at the two engines you
will
notice the AJ26 engine had a large throttle vacuum reservoir that you won't see on the later AJ27s presumably because the cruise control as electronically
controlled by the ECU on the AJ27. And then of course there were several connectors that were different.
Higher capacity oil pump is used to feed the new design VVT units with more oil pressure.
EGR valves elmintated for naturally aspirated models and retained for supercharged models only.
Old Jun 28, 2022 | 09:21 AM
Dog_Man's Avatar
Thank you for your response and detailed explanation. So its a safe bet even if I had a complete donor car for the swap it may not be a smooth swap. I will have to see what goes for (auction for wrecks) and decide how much it will cost after that.
Thanks again.
Jagnewbee2000
Canada
Aug 4, 2017 01:11 PM
beauennis
May 4, 2015 01:36 PM
messiebess
Feb 25, 2015 07:28 PM
jagnicifant
Sep 4, 2012 07:32 PM
johnfrye
Jun 10, 2008 09:50 PM
