tailpipe finisher set screw head stripped
Old Jul 14, 2012 | 03:53 PM
jaguarcraver's Avatar
Default tailpipe finisher set screw head stripped
I was wondering if anyone has any suggestions on how to remove the set screws that hold the tailpipe finishers to the tailpipes. I ruined the head of the set screw on one side and stopped. The heat must've galled the threads.
The tip isn't loose, but I would like to get the screws out and replace them using anti-sieze the next time. I wanted the tips off to polish them thoroughly, and should've left them alone.
Thank you in advance, Louis
Old Jul 14, 2012 | 06:06 PM
Vector's Avatar
Take a Dremel tool with a narrow cutting wheel and grind a slot in the screw. Then you may be able to remove it with a flat screwdriver blade and maybe an impact driver or air impact tool. Some heat, a torch used judiciously, might help too.
FWIW, my right one has a torx bit broken off in it. Happened when I first got the car. I had the same idea that you did to polish them off the car. They look very nice polished with them on the car, lol.
Vector
Old Jul 15, 2012 | 06:24 AM
jimlombardi's Avatar
Hi
This what I do whenever I get a screw or bolt that the head is stripped and rusted in:
I start with a small diameter drill bit and try to first drill enough of the head for the head to fall off. Then I am able to see diameter of the rest of the screw or bolt and the appropiate size drill bit to remove the rest of it.
Jim Lombardi
aholbro1
Dec 29, 2024 06:46 PM
Wolfy
May 28, 2024 08:06 AM
GordoCatCar
Jan 2, 2017 01:10 PM
hoodun
Sep 7, 2015 07:12 PM
tberg
Sep 7, 2015 07:32 AM
