Tensioner pics, What Now?
Old Apr 20, 2008 | 02:16 PM
rodknock95's Avatar
Default Tensioner pics, What Now?
At this point I really dont know what I am looking at. I removed the cover to replace the gasket and replace the tensioner if needed, but I cant tell if its bad. I have taken some pics of it for you guys to give me some advice. LOL
Here they are:
Old Apr 20, 2008 | 02:49 PM
FactoryJaguarTech's Avatar
Default RE: Tensioner pics, What Now?
They are old. You should change them.
Old Apr 20, 2008 | 02:59 PM
rodknock95's Avatar
So they dont look bad to you just old? What I was thinking is, should I leave the car sit there with covers loose until the parts get here or is it safe to put it all back on so it can be driven and then install them later, like a few weeks from now or earlier. Is the oring for the covers going to be reuseable, as long as I dont use rtv?
Blaze
Old Apr 20, 2008 | 03:12 PM
rodknock95's Avatar
After closer examination I can see where the chain has wore two small grooves in the plastic so they need to be changed I guess. Are the primary ones going to be the same way? Should I just wait and do the whole kit and caboodle, primary and secondaries?
Blaze
Old Apr 20, 2008 | 03:23 PM
rodknock95's Avatar
Should I replace the chains as well. FJT, how long do you think they would last they way they look now?
Blaze
Old Apr 20, 2008 | 03:38 PM
jag_genius's Avatar
cud last .. a couple weeks cud last a month.. i wud do the whole thing.. if you leave it any longer .. parts will get expensive..and then the secondary tensioners plastic will come off and pieces will float around in your oil pan.. and the secondary chain will rub metal to metal on the tensioners.. until the chain snaps..
Old Apr 20, 2008 | 04:22 PM
2nd Genius.....
lol....same thing I wrote in answer to PM.
Old Apr 21, 2008 | 07:55 AM
rodknock95's Avatar
I looked at that article on replacing the timing chains that is posted elsewhere one here and they mention that there is a special tool to get the damper off? Where can I get that?
Blaze
Old Apr 21, 2008 | 04:36 PM
Brake buster's Avatar
please see my thread from earlier this year, it may help you decide what you need to do
i will add, that you can NOT fully determine the condition of the upper tensioners without removing them, when new they are white, yours are orange like mine were, and need to be changed, especially as you have gone this far
tensioner change thread
hope this helps
BB
Old Apr 21, 2008 | 07:22 PM
jag_genius's Avatar
i get my pulley off in 10 seconds with no special tools.. if you have an airline and airtools then you dont need any special tools..
Old Apr 21, 2008 | 09:36 PM
Lol I always need to torch the bolt. Would be ok if I took out radiator, but I prefer to leave cooling system intact.
Old Apr 21, 2008 | 11:28 PM
rodknock95's Avatar
I thought mine were the red ones
Old Apr 22, 2008 | 08:23 AM
rodknock95's Avatar
Brake buster, that is a excellent job. I have stepped up doing mine from maybe later, to get it done now. Did you just change the secondary tensioners?
Blaze
mikiep
Dec 20, 2019 07:37 PM
King Charles
Oct 16, 2015 01:25 AM
Sonnyblack
Oct 4, 2015 05:42 PM
millertic
Sep 30, 2015 08:11 PM
