Thermostat
Old May 19, 2008 | 03:58 PM
brgxjr's Avatar
Default Thermostat
can anyone tell me where exactly the thermostat is on a 98xjr? im new to jags and am no pro mechanic, but my jag that i bought a few days ago started to over heat. Im hoping its the thermostat and im getting the part later today. anyone have any tips ,suggestions on changing out the thermo. They would be greatly apprecieted. thnx
Old May 19, 2008 | 08:53 PM
ibjags's Avatar
Default RE: Thermostat
sent you a PM
detailed instructions
good luck
Old May 20, 2008 | 12:18 AM
brgxjr's Avatar
hey thnx alot. i changed it and it still overheated, took out the water pump and the blades were shreded. Looks like the problem was there lol. Gonna try to pick up a water pump this week sometime. I really appreciate the response. definetly helped. thnx again.
Old May 21, 2008 | 07:45 PM
FactoryJaguarTech's Avatar
water pump is only about $60 from dealer. Updated design with very low failure rate.
Old May 21, 2008 | 08:16 PM
ibjags's Avatar
brgxjr
no problem
thats what were here for
make sure you flush the system real good and use the correct coolant
Old May 21, 2008 | 08:46 PM
brgxjr's Avatar
Ya the pump is in, and she's staying cool. I was told i could use that prestone coolant that mixes with any color. Should i not?
Old May 21, 2008 | 09:11 PM
ibjags's Avatar
personally i dont like the idea of mixing coolants
ive always used what was called for
ive seen to many end results of mixed and contaminatedcoolant
just my sincere opinion
Old May 21, 2008 | 09:12 PM
ibjags's Avatar
glad to hear you got the overheating fixed though
Old May 22, 2008 | 04:28 PM
brgxjr's Avatar
ya, i agree. IM gonna flush out the old and put the recommended. thnx again. I love this forum.
Old Jun 17, 2008 | 11:26 PM
brgxjr's Avatar
Drain the radiator. Refer to General Procedures. Retain the coolant drain tray in position to catch any spillage when removing the outlet pipe.
stepNum(0);
if(DanaFlushWrite) DanaFlushWrite();
Disconnect the bottom hose from the coolant outlet pipe.
1)
Release and reposition the hose clip.
2)
Disconnect the bottom hose.
stepNum(0);
Remove the thermostat from the outlet pipe.
1)
Remove the three bolts which secure the thermostat cover to the outlet pipe.
2)
Remove the thermostat cover, the thermostat and the seal from the outlet pipe. Discard the seal.
hoodun
Feb 20, 2023 05:52 AM
mikiep
Dec 20, 2019 07:37 PM
Lubrication
Oct 1, 2015 03:56 AM
zoozth
Sep 29, 2015 07:28 AM
hoodun
Sep 28, 2015 08:32 PM
