Thinking about buying a bone running xjr
Old Sep 16, 2019 | 08:55 PM
2jags1993's Avatar
Default Thinking about buying a non running xjr
I found a yr 2000 xjr for 2,500 who will trade for my 83 240d Mercedes and 400$ ;good news is the car looks immaculate, bad news is it hasn’t run since 09 and since the owner now bought it from auction he doesn’t know the story. So my two theory’s are either some old dude owned it and couldn’t drive it anymore and it sat for a decade or the engine blew back in 09 and the owner didn’t have the money to fix it the problem with option two is that I would think the car would be worth enough in 2009 to justify a new engine. So what are your thoughts and how would one check for a blown engine
Old Sep 16, 2019 | 09:28 PM
King Charles's Avatar
Check for broken timing tensioners via the valve covers.
Old Sep 17, 2019 | 10:09 AM
Jhartz's Avatar
Howza'bout putting your location in your data block.
Old Sep 17, 2019 | 12:52 PM
dwgates's Avatar
Default things to check...
It sounds as if you already "bought" the XJR and if that's the case you might as well dive in. I'd want to spin the engine over by hand at the crank pulley (with a wrench) to make sure there's nothing like an already broken tensioner causing it to have jumped time. I'd certainly want to pull the valve covers and check the tensioner status out as they could be failing but the cams could still be in time.
Personally I wouldn't run any of the 10 year old gas thru the system. You should be able to rig up the pumps to empty the tank and check their function as well. One of mine was bad when I got my 99 and I know I've seen others here that have had both fail on them. It might be smart to at least plan on cleaning the injectors and changing the fuel filter.
I'd also want to change the oil (& filter) and coolant and I'd be surprised if you could just charge a 10 year old battery and have it hold so I guess it would be good to plan for a new one of those.
If you get that far and you determine it's ok to start the old girl you may get hit with some codes but anything that comes up might clean up with a few miles or a fuel system cleaning.
Look the old girl over for rodent related issues as well. Mine gets lived in just sitting for our 9 month long winters here in upstate NY...
Old Sep 17, 2019 | 06:01 PM
yeldogt's Avatar
well .. the good news is a non running Jaguar is still faster than your old 240D ...
We had one (4 speed) ..and I do believe it was slower than our DL Volvo auto.
Old Sep 17, 2019 | 08:06 PM
2jags1993's Avatar
Slow doesn’t even begin to describe this car it only had 52 horsepower new and that was 40 years ago paired with a auto gearbox this thing struggles to make it up my driveway it’s the sort of car that you have to plan your route in advance
Old Sep 17, 2019 | 08:11 PM
2jags1993's Avatar
Thanks, yeah I’m going to look at it in about a week to make sure it’s even a viable project since this isn’t my first rodeo with abandon former luxury cars (you would not believe how hard it is to finding why your ac won’t turn off in a Porsche 928)when checking the vin what month did the old cylinder walls change to the new ones
Old Sep 18, 2019 | 06:26 AM
dwgates's Avatar
Someone with more knowledge of these things will have the numbers or engine dates to use as mileposts but if it's a 2000 it should be well beyond the cylinder wall issues but unfortunately it will also be well into the plastic tensioner body era...
Old Sep 18, 2019 | 07:44 AM
2jags1993's Avatar
Old Sep 18, 2019 | 07:47 AM
2jags1993's Avatar
Default Interior
Separation of the wood isn’t good but expected after 10 years in the Texas sun or a humid garage
Old Sep 18, 2019 | 05:32 PM
Jhartz's Avatar
We have seen this rig before: where in Texas? Near Dallas, there are a capable of guys, from this forum who are really knowing.
Old Sep 18, 2019 | 05:42 PM
2jags1993's Avatar
It’s in Houston I decided to pass on it in favor of s 1979 sl450 and fix my own xj8 which today had a major suspension failure
Old Sep 19, 2019 | 08:32 AM
dwgates's Avatar
Boy that Texas sun! The hood clear coat and cracked dash look very familiar as my 99 came up from the Houston area. Good news is it probably looks pretty nice underneath, except for the deteriorated rubber parts, ask me how I know about that! Good luck with the Merc...
harvest14
Jun 28, 2017 04:03 PM
rmjames1837
Aug 17, 2014 03:15 PM
EyeDoc
Oct 28, 2013 01:16 PM
Don.Key
Jun 9, 2007 12:27 PM
Feb 25, 2007 05:26 AM
