ticking won't stop!!!
Old Apr 14, 2013 | 11:18 AM
jamies xj8l's Avatar
Question ticking won't stop!!!
So I have this odd tick from my engine. It does it cold and hot, sometimes it has to idle for a few to start making the tick. I run 5w40 synthetic diesel oil, my tensioners are new, I'm lost. It's a steady tick tick tick tick and if I rap the throttle I hear something rattle and it goes away for sometimes up to 7 minutes idling. I can rev it slow and the sound follows the rpm. It is best described as a collapsed lifter in a pushrod motor its weird. Any thoughts?
Old Apr 14, 2013 | 02:32 PM
coastaljag98's Avatar
VVT probably losing pressure. Only fix is to replace it but it won't hurt the engine it's just annoying. My 98 xj8 did it at 194k miles. Keep driving it!
Old Apr 14, 2013 | 06:06 PM
princemarko's Avatar
I had the same issue.... tore my engine apart... and.... it was a loose spark plug. Check each of them, the Bosch plugs tend to come out
Old Apr 14, 2013 | 08:22 PM
If it ticks at idle when u crank it up and you rev engine to around 1500 rpm you hear a lil whir a small rattle and then nothing then it's the VVT. That you do not have to worry about. My 98 had 194k and did it and changin the oil weights did nothing. It will not hurt the engine. U did do tensioners so u are good.
Old Apr 15, 2013 | 04:41 PM
I only did the upper tensioners I added sea foam and gave it hell on the expressway today and it's a lot quieter lol
Old Apr 15, 2013 | 09:28 PM
avt007's Avatar
Diesel oil? Why?
Old Apr 15, 2013 | 10:00 PM
It will be fine. I have Rotella in mine.
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
Dagny
Jun 11, 2024 01:06 PM
jagtoes
Sep 9, 2015 09:56 PM
