tire size versus speed shown on speedometer
Old Nov 5, 2017 | 01:03 PM
wrd0225's Avatar
Default tire size versus speed shown on speedometer
Is there any way to adjust speedometer reading when changing tire diameter size?
Old Nov 5, 2017 | 02:00 PM
Mikey's Avatar
no.
Old Nov 5, 2017 | 04:20 PM
JagV8's Avatar
Er... maybe. Needs IDS/SDD or WDS or the like.
That's "no" for most people.
Best avoided, for most people.
Old Nov 6, 2017 | 05:22 PM
Rpach10115's Avatar
If you choose the right tire/wheel combo, you shouldn’t have an issue. If you go to larger rims, go to a lower profile tire to keep the overall wheel diameter the same. Your ride will suffer, but the handling will improve.
Example: going from a 16” wheel to an 18” wheel is easy with a lower profile tire.
I’m running 255/40 on 20” wheels on all 4 corners.
My car originally came with 18” wheels. I have exactly same wheel diameter using the 20” with the low profile tires. The speedo was verified to have the correct reading after installation.
Old Nov 6, 2017 | 05:54 PM
ericjansen's Avatar
Rpach is very right there!
Tires with outside diameter of 676mm (26.6") are very very close.
wrd0225
Jun 4, 2017 02:12 PM
aholbro1
Nov 29, 2014 05:54 AM
jonbugh
Jun 17, 2009 10:19 PM
