touch throttle wont start?!
Old Aug 23, 2010 | 03:41 PM
beans's Avatar
Default touch throttle wont start?!
could anyone tell me why if i touch the throttle on my xj8 2000 model the car will not start i have to leave it for a full day sometimes before it will start again
Old Aug 23, 2010 | 04:59 PM
hlgeorge's Avatar
Please expand on that question. What do you mean "if I touch the throttle"? Does it start only on cold starts?
Old Aug 24, 2010 | 01:10 PM
beans's Avatar
Default xj8 wont start if throttle pressed
thanks for your reply, in answer to your question. if anyone accidentally presses the throttle before they try to start my xj8 the engine never starts. this happens whether the car is cold or hot i then have to leave the car for several hours before i can start the engine.
Old Aug 24, 2010 | 04:16 PM
hlgeorge's Avatar
Wow! That's a new one on me! Never heard of that issue on any car. Maybe a tech can give you some insight.
p.s. Does this mean that the starter doesn't work(dead silence) or the starter turns the engine but the engine just doesn't ignite.
Old Sep 5, 2010 | 12:50 PM
beans's Avatar
Default no start once throttle has been pressed
thanks for the reply hlgeorge, the engine turns over on the starter ok, but the car never starts once the throttle pedal has been pressed the jag i had before this one did the exact same thing, also i know two of my friends jags have the same symptoms. i have thought it has to do with flooding in some way but as it is ecm controlled i dont see how that is possible any help greatly appreciated
Old Sep 5, 2010 | 06:47 PM
hlgeorge's Avatar
You may want to post this question in the XJ8 forum too.
Something to do with the throttle body or the throttle position sensor maybe?? Has it set any codes?
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
