trans valve body / solenoid replacement - 98 VDP
Old Apr 3, 2012 | 07:41 PM
domer94's Avatar
Default trans valve body / solenoid replacement - 98 VDP
im about to have this work done to solve the problem of some semi-hard downshifts and somewhat hard drive engagement. upshifts are otherwise good and all external possibilities have been either tested or replaced. this is a replacement trans and the pump seals / filter and almost new torque converter were installed along with it. has anybody had this type of work done and what was the result? this was the alternative to pulling the trans again which is much more labor cost.
Old Apr 3, 2012 | 07:59 PM
avt007's Avatar
It can all be done by pulling the oil pan, so the labour should not be much. I can't say if it will fix your problem, though. Good luck.
way2far
Aug 31, 2022 09:26 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
