Transmission noise
Old Feb 24, 2011 | 08:51 AM
chrisd's Avatar
Default Transmission noise
I own a 2000 xj8. The transmission A drum failed a common thing I was told. I had a local transmission shop overhaul with updated A+B drums. It shifts fine but now chatters in the morning when cold and has a humming noise at 50 to 55 mph in drive mode. But when shift to sport mode goes away. Transmission place says transmission is fine and is very common problem with no repair fixes. Can anyone help me? The car did not do this new. Thanks
Old Feb 25, 2011 | 01:18 AM
DB6's Avatar
DB6
ud
Default keep it in sport
why not
to be honest I never see that much dif between the two settings anyway.
Old Feb 26, 2011 | 01:19 AM
veffremov's Avatar
Sports mode turns off 6th gear. Try switching manually to 5th with the J-gate in normal mode and see if the noise disappears.
Old Feb 26, 2011 | 01:40 AM
u102768's Avatar
I guess you haven't spotted that the OP said he has a 2000 XJ8 so will never get 6th gear!
Also sports mode on an X350 only inhibits 6th gear when an enthusiastic driving style or a demanding road is detected.
When cruising conditions are detected, 6th gear is made available again to maximise driving refinement and economy.
Old Feb 26, 2011 | 10:30 AM
amcdonal86's Avatar
Why doesn't somebody move this to the right forum?
Old Feb 27, 2011 | 04:15 AM
Cadillac's Avatar
Thanks , moved
Old Feb 27, 2011 | 02:01 PM
QuadManiac's Avatar
So now we have three identical posts, same issue from the same member in the same place... consolidation possible?
https://www.jaguarforums.com/forum/s...ad.php?t=50396
https://www.jaguarforums.com/forum/s...ad.php?t=50395
https://www.jaguarforums.com/forum/s...525#post310525
Old Feb 28, 2011 | 04:10 AM
Cadillac's Avatar
Ok, this one is locked , please follow the link below
1LowCat
Feb 23, 2016 07:19 AM
Poet
Oct 6, 2015 09:40 PM
tsimms7
Sep 15, 2015 12:43 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
AtholC
Sep 9, 2015 09:07 PM
