Trouble looking for suspension part urgently
Hi All,
My MOT failed on something in regards to the suspension ball joint. The part it seems they cannot procure so I have to procure it myself as they have limited suppliers they are allowed to deal with.
The part seems to be JLM21171 the lower wishbone, thing is I can't find it in stock anywhere without having the buy all three parts together. Either this or if anyone knows exactly what suspension ball join part number which attaches to this part is that would be so so helpful
Thanks for any help
Thanks for any help
lower BJ is MNC1350AA, same as X100. at one point they were a service part but it was removed
if you buy a ball joint you can do it with just the knuckle off...it's not fun because of how narrow the arm is but it's doable
The ball joint is MNC1350AA. Some of the Jag parts suppliers offer Lemförder 2698001 as an aftermarket substitute for this part. You can google for the mentioned MNC or Lemförder.
According to what I have read, extracting the old BJ could be a challenge and it seems that at least a 20T press is needed with lots of heat and some hammering.
Hopefully one or the other will be enough for the garage to do the job. It's a shame the part is so scarce somehow or that you can only but the whole unit.
The rear straight link that attaches to the brake hub... What's that called? I need to replace them.
Inner tie rods? Control arms? Front or Rear?
