Trunk Gas Struts
Old Apr 3, 2014 | 11:59 PM
reberle's Avatar
Default Trunk Gas Struts
One strut failed on 04 XJ8 - I plan to replace both. Are the after market struts offered on discount parts sites worthwhile? Or should I stay with OEM type. Do the C like metal clips at strut ends need a particular tool?
Old Apr 4, 2014 | 12:05 AM
XKRacer's Avatar
Can not give an opinion on the strut quality but just use a small flat blade screw driver, no need to remove the whole clip just lift it a little bit and that will be enough to release it
Old Apr 4, 2014 | 06:41 AM
jaguarbill's Avatar
I bought mine in January from the ebay seller below and am happy with them so far.
For Jaguar Vanden Plas XJ12 XJ6 XJ8 Rear Trunk Lid Lift Gate Shock Strut Damper | eBay
Bill
Old Apr 4, 2014 | 07:31 AM
ericjansen's Avatar
I did mine last week while the trunk was empty.
It really helps if all the lining & wheel is out, as it gives just that extra needed space.
It also helps if you can sit in the trunk.
It is tight, but much easier as some other threads suggest.
The small screwdriver is a must, small hands help .
In my case there were tie-raps on the struts holding cables, be careful before you pull them out.
Oh yeah, have an extra pair of hands ready to hold the lid, it is quite heavy once the strut is gone, even if you do them one by one ....
Old Apr 4, 2014 | 08:24 AM
reberle's Avatar
Appreciate the replies - I can see myself hitting the paint with the screw driver or strut - sounds pretty easy - the tip on having someone hold the trunk is something I would be swearing about - although likely would of propped with wood 2 x 4 -
Old Apr 4, 2014 | 09:19 AM
Aonsaithya's Avatar
While you're at it, might consider this mod
EDIT:
Oh, right, wrong tab -> wrong sub-forum. Oh well, if I sell the X in the summer and find an X308, I'm going to try adding such springs to the struts of that too anyway.
GordoCatCar
Jan 2, 2017 01:10 PM
XJsc-guy
Nov 23, 2015 01:56 PM
mrplow58
Sep 17, 2015 08:06 PM
34by151
Sep 6, 2015 05:14 PM
02jagstype
Sep 4, 2015 08:20 PM
