Trunk Opener Fuse
Old Feb 16, 2008 | 09:41 AM
FactoryJaguarTech's Avatar
Default RE: Trunk Opener Fuse
can you open it with the key? Hole is on the xj8l badge
Old Feb 16, 2008 | 09:33 PM
Spanner's Avatar
A common problem with these XJ's is broken wires. There is a harness that runs along the passenger side trunk hinge, and through repeated use some of the wires tend to break. Just something to check out as I fix a few of these a month. I am assuming (never a good idea) that the fuse is good, and the latch is in good working order. I don't remember off the top of my head which fuse it is... sorry.
Old Feb 18, 2008 | 06:41 PM
Possibly in Valet mode.
Funny how different areas of the country see different problems. I have never had that harness go bad.
Old Feb 18, 2008 | 07:09 PM
Spanner's Avatar
Yeah, I've seen a lot of strange problems, even the tech line was baffled at a few.
Old Feb 18, 2008 | 08:59 PM
ibjags's Avatar
i just repaired trunk harness on r/h hinge last fri
ive seen it as far back as 95
usually happens next to the zip tie securing harness to lid hinge and or behind the cover at the hinge
Old Feb 19, 2008 | 04:49 AM
Wow. Again a state away can make all the difference.
Old Feb 19, 2008 | 06:46 PM
jag_genius's Avatar
ya i have had a couple but not for a long time..
Old Mar 25, 2008 | 03:27 PM
The microswitch if failing would either show trunk open all the time or wouldn't show it at all when open. Dealer has the switch.
BadKat174
May 26, 2023 12:29 AM
abonano
25
Sep 25, 2015 10:43 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
findre
Sep 10, 2015 05:46 PM
speacock
Sep 10, 2015 12:14 AM
