Upper shock bushing failure?
Old Feb 6, 2021 | 10:05 AM
92/93 XJS's Avatar
Default Upper shock bushing failure?
So, I bought my 2001 XJ8 base model last year with extensive docs back to 2008. Records indicate upper bushings and shocks replaced 4 years ago. Oddly, lately I'm hearing thuds from front end going over speed bumps, etc. I check the upper mounts and find left side obviously toast, but nothing really visible from right side. I will change both, but it raises a question. What is the cause of upper bushing going bad? In particular, why would one side go noticeably more than the other? I realize after 50yrs of playing with cars, I've just accepted bad upper shock bushings and replaced them without looking for the root cause. Thoughts????
Dave
Old Feb 6, 2021 | 12:29 PM
Jhartz's Avatar
Miles, heat and cold, vibration, poor quality in the replacement (I found rebuilding with neoprene was way too hard, particularly in very cold). My left took more of a beating than right side -- replace with Mahle replacement, seems better than Uro (either much cheaper than OEM from dealer).
Old Feb 7, 2021 | 09:09 AM
jrb53's Avatar
Make sure you change the bump stops on top of the shocks the are just as important as the upper shock mounts. they are part of the cause of upper bushing failure
Old Feb 23, 2021 | 11:26 PM
92/93 XJS's Avatar
Thx! Ordered and news when done.
MickeyR
Dec 30, 2020 12:20 PM
Billieg
Sep 18, 2019 03:08 PM
n17gary
Apr 16, 2017 03:14 PM
Jon89
16
Jan 18, 2017 02:10 PM
Alvin Burns
Dec 2, 2015 04:16 PM
