Urgent help! Valve cover bolt
Old Aug 21, 2018 | 09:28 AM
vincent661983's Avatar
Default Urgent help! Valve cover bolt
Changing the valve cover gasket the third time during my ownwrshio.
Need the new bolts but I can't find the reliable information.
Found some old thtead thay should be the gerneic M6 X 1.0 bolt, is that correct?
Thanks in advance
Old Aug 21, 2018 | 10:14 AM
Sean B's Avatar
Should be but they're flanged so you might need to use a washer and the correct length bolts - maybe take one out the other side and get it matched at the hardware store?
Old Aug 21, 2018 | 12:25 PM
avern1's Avatar
A standard metric bolt will not work correctly for a cam cover. The bolts and the studs all have a special configuration to contain the seal rings that stops oil from leaking thru the fastener. I have attached an excerpt from the SNG Barratt catalog ( a forum sponsor) that show the shapes and seals for the cam cover.
David Bedoya
Jan 15, 2017 04:12 PM
XxSlowpokexX
Mar 25, 2016 07:07 PM
boostedhks
Sep 3, 2011 09:46 AM
prelude4ws
Sep 30, 2010 12:19 AM
lonewolf583
Jul 27, 2009 10:18 PM
