using obd
Old Feb 8, 2012 | 03:00 PM
jameson's Avatar
Default using obd
Hi all,
trying to read codes for the check engine light which is on.
I have the creader generic obd 2 but when i plug in it just fashes 1-2-3-4-5 and then e which means its not gettting a connection.
I tried when the car was on ...off and igntion on with car off.
am i doing something wrong ?
Thanks !
Old Feb 8, 2012 | 03:44 PM
avt007's Avatar
Mine will only read when the engine is runni ng for some reason. Is your reader on a laptop?
Old Feb 14, 2012 | 09:34 PM
jameson's Avatar
no, its just one you plug and the codes display...the check engine light went away....but has reappered today :-(
Old Feb 15, 2012 | 05:18 AM
Sean B's Avatar
try an obd scanner that works! there's a list of known good ones on this forum. It should read when the key is in position II. Initially loading the SAE protocol. The Elm readers seem popular. What make/model is yours and have you tried it on another car? at $20-30 they're cheap enough things.
Old Feb 15, 2012 | 05:23 PM
avt007's Avatar
Mine is an ELM327 type device, hooked to a laptop. It works great for OBD stuff, but won't read Jag specific codes. The problem with car specific devices is they may not work on other vehicles.
Old Feb 15, 2012 | 08:02 PM
test point's Avatar
None of the generic OBDII readers will read the Jaguar specific codes. Autoenginuity is the low price leader at just under $500 that reads all the codes.
Check out this link on all the readers.
https://www.jaguarforums.com/forum/g...oved-**-33347/
Old Feb 15, 2012 | 09:08 PM
plums's Avatar
However, now that the official Jaguar standard is the Mongoose JLR or other J2374-2 device, the autoenginuity does not look quite so cheap as compared to factory. The difference is that the supported J2374-2 devices can program modules in addition to the read-only capabilities of the AE.
Old Feb 15, 2012 | 10:10 PM
Boomer from Boston's Avatar
To use the Mongoose, it looks like you also have to buy a factory subscription to (???) in addition to the Mongoose. By the time the dust settles and you have bought everything you need, you might need to spend $1000 or so to be in business.
Old Feb 16, 2012 | 12:36 AM
Estilian's Avatar
What do you understand by saying "Jaguar specific codes"?! Do you get any codes at all with the ELM327?! I've tried to use one with Bluetooth and Torque Pro application on Android phone - it gets all the live data, everything is good but when I try to read the Error codes it processes and after reaching 100% of reading it shows up "No faults found" which in my case is impossible
And what version of ELM327 are you using - 1.4 or 1.5?!
Old Feb 16, 2012 | 06:39 AM
Sean B's Avatar
Do you have a Check engine/warnings?
Old Feb 16, 2012 | 06:51 AM
jameson's Avatar
I have the check engine symbol but no message and no warning light...
Old Feb 16, 2012 | 08:33 AM
adriaxj8's Avatar
Default Picture of ODB port
Hello,
I would really appreciate if you can send me a picture of the OBD port in the car because I cannot find it.
Thanks in advance from Spain!
Old Feb 16, 2012 | 09:02 AM
Sean B's Avatar
@ adriaxj8
its under the steering wheel/dash towards the transmission tunnel.
Old Feb 16, 2012 | 09:03 AM
Sean B's Avatar
probably an O2 sensor code?.....get the code pulled from the car with an obd reader
Old Feb 16, 2012 | 09:12 AM
JKo's Avatar
JKo
I have ELM327 1.5a, and it reads the codes just fine using EasyOBD II. Well, I say it reads the codes, but my car has so far only given the P1111 code...
Old Feb 16, 2012 | 02:46 PM
Estilian's Avatar
I would like to ask you for a favor... Can you send me (here in this thread or as private message) a link to ebay item (for example) with the exactly the same reader you have.
I ask you for this because I already tried two different obd readers (one with USB and one with Bluetooth) that have nothing to do in between (neither shape or manufacture) and they both were described as ELM327, but can't read codes I want to be sure that when I order something from ebay it will be (at least as appearance) the one I need
Old Feb 16, 2012 | 04:10 PM
Boilerpete's Avatar
I have a relatively cheap(around $125) Actron CP9175 that has read any code my XJ8 has ever thrown.
Old Feb 17, 2012 | 04:08 AM
JKo's Avatar
JKo
This is where I bought mine: ELM327 USB Vehicle OBD-2 Scanner Tool - Free Shipping - DealExtreme
And there are several like it in eBay as well.. elm327 1.5a | eBay
Old Feb 20, 2012 | 01:08 AM
Fyrplg's Avatar
You may want to try one from obd.com . If you have a laptop, it uses usb hookup.
Works great for codes, also check item when engine on monitor rpm,speed, o2 sensors and other thing while driving. When you get the codes you can save the file , print it and it gives you the code results. I really like mine. Cost about $100.00 and the support is great. The guys name is Mike.
Good Luck PDF
Old Feb 20, 2012 | 11:30 AM
sovejag's Avatar
Hi, i've the autoenginuity and IDS factory.
Autoinginuity is a good reader for the price.
Marc
philwarner
25
Jun 26, 2021 05:43 AM
carl purchase
Oct 14, 2015 06:14 PM
foxbottom
Sep 25, 2015 03:24 PM
Bob Gelston
Sep 14, 2015 11:08 PM
