Valve cover
Old May 12, 2016 | 11:29 AM
maniqz's Avatar
Default Valve cover
Hi, turns out my valve cover has a crack, can an xj8 or xk8 valve cover fit my XJR? I see mostly xj8 and xk8 on eBay.
Old May 12, 2016 | 08:27 PM
Highhorse's Avatar
Yes, you just need to match the engine size, 4.0, 4.2 etc....
Old May 12, 2016 | 08:45 PM
motorcarman's Avatar
Your best bet would be a cam cover from a 2000-2003 4.0 Supercharged Engine because you don't have VVT. The Normally Aspirated engines have the VVT actuator protruding though the cover with a seal installed.
The earlier covers (AJ26) will work but the gaskets are different and are not as common (They are orange for one side and grey for the other) and are thicker. The spark plug well seals are also different (one is in pairs instead of individual).
Do some research and make sure you get a match to what you have.
bob
Old May 13, 2016 | 12:05 AM
maniqz's Avatar
The earlier covers AJ26) will work but the gaskets are different and are not as common (They are orange for one side and grey for the other) and are thicker. The spark plug well seals are also different (one is in pairs instead of individual).
bob
Bob and Highorse...thanks for chiming in. I actually got a replacement valve cover from a junkyard. Stroke of luck. But I'm luckier being on this forum where everyone are so helpful. You all are so precious in keeping my car in tip top shape. And to think I had trouble deciding on buying a Jag because of repair issues, cheers to this generous forum. Thank you.
Old May 13, 2016 | 05:30 AM
Highhorse's Avatar
Thanks for the correction Bob, I was unware of that difference.
ericjansen
Aug 29, 2016 11:52 PM
Terry007
Apr 22, 2016 05:04 PM
dwgates
Apr 22, 2016 08:28 AM
Bcrary3
Apr 22, 2016 02:44 AM
jaguarVP96
Apr 22, 2016 02:21 AM
