Valve Cover Bolts
Old Feb 20, 2015 | 02:21 PM
JBfountain's Avatar
Default Valve Cover Bolts
Does anyone know what the size of the valve cover bolts are? When I was taking off my valve covers some of the bolts broke. I did not finish removing them because I want to be prepared to fix the damaged ones when I take them off. This is my only vehicle, so when I remove the valve cover I won't have a way to get the items that I will need to repair them.
2002 Jaguar XJ8, 4.0L
Old Feb 20, 2015 | 04:11 PM
motorcarman's Avatar
The cam cover bolts are NOT regular bolts. They are bolts with a 'spacer' and rubber grommet/isolator. The rubber rings are replaceable but the bolts are made with the spacer installed. Your local Jag dealer should have the one's you need.
The one's in the rear near the throttle are DIFFERENT in as much as they are a bolt that is separate from the spacer. It is a different metal and has something to do with the CMPS near it.
I wish you were located near me as I probably have a box full of good used somewhere in my shop.
bob gauff
Old Feb 20, 2015 | 05:42 PM
WhiteXKR's Avatar
In addition to the above, if the bolts broke, they might have been over-torqued when they were installed. Inspect the plastic valve cover carefully for compression damage. It might not seal properly even with a new gasket if it was deformed or cracked.
Old Feb 25, 2015 | 01:19 AM
JBfountain's Avatar
Wink Need Size PLEASE
Thank you for your replies, but what I really need is the size and thread count for the bolts. I want to have what I'll need to repair the threads on the head incase I am unable to remove the broken bolts without drilling them out. I know that I can get the bolts at the dealer or a salvage yard, but I'll have to pick up a thread repair kit just incase. I won't be able to go anywhere once I remove the cam covers. Yes I know that I can get the size after I pick up new bolts, but I just thought someone would know what size they are.
Old Feb 25, 2015 | 03:11 PM
The bolts are M6 X 1.00
bob gauff
Old Feb 27, 2015 | 11:35 PM
JBfountain's Avatar
Default Thanks motorcarman
Thank you Bob. That's exactly what I needed.
Old Feb 27, 2015 | 11:41 PM
JBfountain's Avatar
Originally Posted by Jason-EnzosAtlanta
When the bolts snap off you can generally use a LH drill bit to get them back out..regards..Jason
Yes thank you, and a bolt extractor works also, but sometimes you have to drill out the the bolt, tap the hole and install a threaded insert.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
sadepol01
Sep 11, 2015 05:26 AM
jaggermang
Sep 8, 2015 07:07 PM
