Vvt service?
Old Sep 25, 2010 | 06:29 AM
alckc's Avatar
Default Vvt service?
My 98 VDP has a ticking that disappears when the engine warms or when I rev the car. Had the tensioners checked are are fine. Read on the board to use a heavier oil because of the VVT sticks.
Is there any parts to service or clean on the VVT soleniod.
Thanks in advance.
Old Sep 25, 2010 | 06:37 AM
sparkenzap's Avatar
I would not think it was the VVT solenoid that was ticking, but rather the vvt unit itself. You could have a look when yo had it apart to check the tensioners.
Old Sep 26, 2010 | 12:47 AM
alckc's Avatar
will take a look at the vvt when i take off the covers again. thanks
Old Sep 28, 2010 | 07:40 AM
Sinister 1's Avatar
Mine were noisy when I used 5W-30 Mobil One and are silent with the 15W-40 that I have in there now.
I heard from a local mechanic to replace the seals on the VVT valve where it goes into the center of the sprocket hub. From what I remember it was a plastic split ring.
I'm going to change mine soon as the weather is getting colder here and my next oil change will put me back in the thinner stuff.
Ken
Old Sep 30, 2010 | 02:28 AM
alckc's Avatar
been using 5-30, will try heavier weight at next oil change
Joachim1167
Nov 7, 2020 09:18 PM
LilaJagHubby
Oct 6, 2015 02:56 AM
Nigels420G
Mark V - X 420G
Sep 27, 2015 03:48 PM
SD96XJ6L
Sep 25, 2015 10:53 PM
