Wanting to convert 98' XJR steering knuckle to 00' XJ8 knuckle
Old Mar 27, 2016 | 06:58 AM
Addicted2boost's Avatar
Default Wanting to convert 98' XJR steering knuckles to 00' XJ8 knuckles
I have a bad wheel bearing on the front of my 98' XJR. I know that the front wheel bearings are considerably smaller than any 99' - 03' XJ8/XJR. I have access to both front knuckles off of a 00' XJ8 that's already loaded with the wheel bearings and hubs. What I want to know is that will it mess with my alignment geometry if I put the later XJ8 knuckles on my early XJR?
98' really was an experimental year wasn't it?
I am completely capable of installing new wheel bearings in the current front knuckles but, the idea of having the larger wheel bearings are because I plan on doing long distance trips with it and I don't want to contend with a possible issue along the way. I'm not trying to reinvent the wheel, I just want to make this car as durable as possible and I have resources readily available to me.
A long story short is that this car practically fell in my lap and I plan on keeping it so it it's not like I went looking for an odd ball year XJR or else I would've gotten the 99'+.
Anyways, I'd appreciate your feedback.
Old Mar 27, 2016 | 07:43 PM
motorcarman's Avatar
Many people have installed the 80mm bearing hubs instead of the 76mm bearing hubs.
There shouldn't be any real differences but you might want to have the front suspension checked/aligned.
bob
Darrenmb
Nov 14, 2020 01:20 PM
gabrielbecheanu
Mar 18, 2016 12:36 PM
reb1999
Mar 6, 2016 08:26 AM
molotov369
Mar 3, 2016 01:33 PM
al_roethlisberger
Mar 1, 2016 06:50 PM
