Warning Lights XJ8 2001
Old Aug 19, 2019 | 03:40 PM
Joe Ellis's Avatar
Default Warning Lights XJ8 2001
Just today brought a 2001 XJ8 lovely. Garage said there are no warning lights on the dash, but when collected there was. They are willing to sort it perhaps after a few days use. I have taken two photos. Apart from this, the Jaguar drives like new.
Please help and thank you in advance/\.
Old Aug 20, 2019 | 02:06 AM
Welcome to the forums Joe,
I've moved your question from General Tech Help to X308 forum. This is the place to post questions about your model.
The vendor is correct about the ABS warning light and the Trac/ASC messages. The vehicle is safe to drive and it is likely to be a wheel sensor fault. It could also be a partially discharged or failing battery.
Presumably the seat belt warning light was only illuminated when the belt was NOT fastened? If it remained lit when the belt was fastenedt, there is a problem with the restraint system which is potentially dangerous.
Old Aug 20, 2019 | 03:01 AM
M. Stojanovic's Avatar
Practically every X308 suffers this, sooner or later. It is better to do an OBD scan to establish where exactly the trouble is instead of going around all of the wheel sensors. And it may not be a wheel sensor. A probably more common cause of the trouble are two solders inside the ABS computer, on the pins where the ABS motor is plugged in. The solders deteriorate/crack over time and the ABS motor gets intermittent power. In such a case, re-soldering these pins solves the problem.
The said repair involves removal of the ABS computer (the black box), opening it up and doing the re-solder. As it is often very difficult to open the ABS box (the lid is glued in addition to being clamped-on with some small circlips), cutting the corner of the box or cutting a hole (see pic) is an easier way. The solders to be repaired are marked by yellow lines. Cutting the corner or a hole has to be done very carefully in order not to damage the electronics below.
Coops5863
Aug 25, 2019 09:34 AM
jhennigar1
Oct 29, 2016 11:24 AM
chrisp1981
Jan 31, 2013 06:33 PM
Greg561
May 19, 2009 08:07 PM
