Washer fluid nowhere to be found?
Old Apr 10, 2014 | 07:45 PM
ObxjagXJ8's Avatar
Unhappy Washer fluid nowhere to be found?
I have checked my washer fluid many times, and it is always full, but I can't ever get it to work? The hose from the external opening to the wiper is clean and isn't cut, but still nothing. Any suggestions
Old Apr 10, 2014 | 10:42 PM
jimlombardi's Avatar
A lot of electronics pass through fuse #7 15 amp in the Left Hand Heelboard - Left Hand side - US -driver side rear seat (lower panel).
when that fuse blew, I noticed that a number of items were no longer working (windscreen washer was one of the them) on our 2001 XJ8.
Information from 1998 Vehicle Care Handbook:
Rear Compartment Fusebox - Left-hand Heelboard
Fuse 7 15 Amps - Body processor module (battery supply for solenoids, lamps and motors).
Our 2001 Vehicle Care Handbook has the info for that fuse.
Jim Lombardi
Old Apr 18, 2014 | 10:04 AM
NJ2003XJ8's Avatar
Does the pump make noise when you press the button? If it does the electrics are fine, so you need to check if pump is pumping water , and where water goes.
If you disconnect wiper's hose from that connector(carefully not to break it!) and press the button - water should come out through opening, if it does - wiper's hose or sprayer is bad.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
al_roethlisberger
Sep 9, 2015 09:14 PM
Tar
Sep 6, 2015 11:24 AM
