Washer Fluid Reservoir Fix?
Old Mar 29, 2019 | 10:03 PM
Ordhyait's Avatar
Question Washer Fluid Reservoir Fix?
Scraped the washer fluid reservoir on my '98 XJ8L and now it has a couple minor leaks. Short of replacing it, is there anything specific this forum would recommend to do about it? Melt some plastic onto it? The old gauze/epoxy trick?
Old Mar 29, 2019 | 11:02 PM
King Charles's Avatar
Replacement readily available on eBay etc.
Edit :
You can try JB MarineWeld epoxies or similar but it will likely leak again.
Old Mar 30, 2019 | 01:57 AM
M. Stojanovic's Avatar
"Minor" leaks? I don't think any glue would adhere well to it being PVC (I believe). Probably the best way to repair it would be using a PVC welding rod and a hot air gun. Hot air welding rods, made of different plastics, are available on Ebay.
Old Mar 30, 2019 | 07:25 AM
CharlzO's Avatar
best I could tell would be to pull it out and add another layer of fiberglass and epoxy. But at that point, you've got it out of the car, and investing money, cheaper to just replace the whole tank with a used one as suggest above. Last one I saw was like $70 and was a complete tank top to bottom, pump and all.
Old Mar 30, 2019 | 08:02 AM
xjack's Avatar
Fixed tank on my older car with Plastic Tank & Radiator Repair Kit from ebay, comes with fiberglass and is a bit elastic after dry, held well till the end
Mpowerr
Sep 24, 2018 12:20 AM
Stuart S
Oct 18, 2016 03:33 AM
King Charles
Jul 18, 2014 02:51 AM
Dan Bennett
Feb 3, 2013 12:46 PM
MTZGR777
Jul 25, 2011 04:58 AM
